Old 05-06-2018, 11:21 PM   #1
Ekliptix
Ekliptix's Avatar
Help with details about my next wheel/time combo (original hubcaps/lowered)
The attachment shows an example of what I'm going for. My truck is currently on rallys.
Parts needed:
Hubcaps - found 'em.
Rims - What are they? 15x? I imagine they're easy to find. Do I need any special clips to accept the hubcaps?
Tires - I imagine it's a coker tire or something similar? Any direction?
That'll it take for the wheel tire combo attached?
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 05-06-2018, 11:28 PM   #2
Boog
laying low
Boog's Avatar
Re: Help with details about my next wheel/time combo (original hubcaps/lowered)
Those wheel covers will snap on to your current rallys if you like and you can run wider Diamondback white wall tires. I'll see if I can dig up a pic of a member's truck with that setup.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-07-2018, 02:27 PM   #3
Ekliptix
Ekliptix's Avatar
Interesting, so those hubcaps can fit on my 15" rally rims, eh? I'm so use to seeing them on the skinny rim + skinny tires like in the photo I attached, I'm definitely interested to see the example you mentioned on a wider tire.
Old 05-07-2018, 10:36 PM   #4
Boog
laying low
Boog's Avatar
Hey slap one of those wheel covers on one of your wheels and stand back. You may not like the wide wheel/full wheel cover combo.
Well I've looked through a 1,000 or more pics I have saved but I cannot find the ones I remember. I've lost a few in the crashes.
Anyway the truck I remember is a 69 or 70 silver and white short fleetside. It had chrome rallys and 10's on the rear with I believe a 295/50/15 tire with about a 2" white wall. If I remember right he changed his direction and sold those tires here in the forum classifieds a couple years ago. For the life of me I cannot recall his username either. He did not have wheel covers over the rallys but the point of reference is the wide wheels and white wall tire combo. I thought it looked great.
Maybe this will ring a bell and someone else remembers that truck.
Here's an alternative wheel cover I like from a 69 Vette.
Boog
primer is finer
Old 05-07-2018, 10:55 PM   #5
Yes, the wheelcovers will mount on the rallye wheels. Tires appear to be 235/75-15 whitewalls still available through normal channels
https://www.ebay.com/itm/Set-of-4-Co...wAAOSwc6paAd8e
Old 05-08-2018, 01:52 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have 15 x 7 rallys with 235/75 15 tires and those P01 hubcaps on a stock height truck.. The 7 inch rim makes the 235 tires pop a little wider.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-08-2018, 06:42 AM   #7
The '90 Blazer I bought new came with 235/75s mounted on 8" rallyes. I had found a rare set of 8" steelies about 15 years ago, had them powder coated juicy red with the intentions of mounting factory wheel covers on them, and have Diamondback make up a set of 3/8" whitewall 275/60s for an old man look yet road hugger wide oval look at the same time. Then I realized it would be a waste of those steelies only to hide them when far more common rallyes could be used. So I saved the juicy reds for hubcaps and did the same red on rallyes
Old 05-08-2018, 12:17 PM   #8
PipsC10
PipsC10's Avatar
I have 15x7 rallye wheels with cooper trendsetters 235/75/15. I absolutely love the truck and the look you are after
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 05-08-2018, 01:25 PM   #9
Ekliptix
Ekliptix's Avatar
^Thanks for the inspiration! I don't know if I've seen your truck before. I just read the build thread. Well done! Love those gauges too. I want to be as low as yours, so hopefully I can make that a reality in the future. Those cooper tires are 100% what i'm going to go with, and a great price. Just shopping for some cheap rally rims now, so I can keep my current 8" rallys + 275 BFGs as a separate set.
Old 05-09-2018, 12:44 PM   #10
raggedjim
raggedjim's Avatar
You can use the cheap "wagon wheels" too. Sometimes easier to find than rallys.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 05-09-2018, 12:51 PM   #11
Ekliptix
Ekliptix's Avatar
Good call. Does anyone have a close up photo? What color is the wheel itself? Grey, white?
I got a set of hubcaps on ebay this week for $225US. There were not many available, so I'm happy.
Old 05-09-2018, 01:59 PM   #12
raggedjim
raggedjim's Avatar
If you mean the wagon wheels they are usually white or black. I painted mine.
If you mean the original wheels, I'm not sure...
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 05-09-2018, 02:15 PM   #13
PipsC10
PipsC10's Avatar
I had mine powder coated white
Old 05-09-2018, 02:16 PM   #14
PipsC10
PipsC10's Avatar
Thanks!
Old 05-28-2018, 05:44 PM   #15
Boog
laying low
Boog's Avatar
I was thinking about your wheel cover/white wall look and that truck you posted up there is familiar so I just had to look it up. That particular truck is owned by member Bill Neumiller in Minnesota. He had a set of low and wides on it and changed to the setup you posted. I found a few more pics of his 72 Cheyenne.
Per Bill on the current setup, 'wheels are stock 15x6 with P235/75R15 with 3/4" whitewall. The truck was dropped when I purchased it but I'd have to guess it's a 3/4 static drop. I added a rear sway bar and quick ratio box for handling. Drives nice.'
I like it both ways.
Boog
primer is finer
Old 05-28-2018, 07:51 PM   #16
BCOWANWHEELS
Caps on above look so much better
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Thread Tools
Display Modes
