05-13-2018, 11:48 AM | #1 |
Backwards upper rad hose outlet? Pointing other way? Swivel?
I'm considering a Ron David triple-pass radiator. They say the triple pass (where it makes 3 crossings across the radiator instead of 1) boosts cooling capacity by about 25% in the same package size.
The downside is it moves one of the hose outlets - they wind up on the same side. Since the water pump comes out the passenger side bottom, that means the top has to come out the passenger side top, which is backwards from stock. Does anyone make a thermostat housing that is basically pointed the mirror image of the factory one? I could likely get a swivel but I'm afraid it'll leak and look too out of place.
05-13-2018, 01:14 PM | #2 |
Post Whore
Re: Backwards upper rad hose outlet? Pointing other way? Swivel?
I don't know of a passenger side outlet but a forward facing outlet is not a problem then it would be a matter of finding a hose off like a ford 460, 302, AMC 360, or a BB dodge that feeds to the passenger side. Time to buy a pizza for your favorite auto parts store.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-13-2018 at 01:22 PM. |
05-13-2018, 01:36 PM | #3 |
A single pass or regular style radiator has the inlet/outlet on opposite sides. A double pass puts them on opposite sides since it turns and goes back where it came from, right? Seems a triple pass would have the same inlet/outlet orientation as a single pass. What am I missing?
05-13-2018, 01:53 PM | #4 |
Post Whore
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-13-2018 at 01:54 PM. Reason: Forgot link |
05-13-2018, 07:50 PM | #5 |
My 65 Caprice uses a right side upper hose outlet.
Big block or small block uses the same part. Try to find one and it will work. You can probably use the same upper hose too! If you can find it in iron-Much better! Mike. Last edited by 100%Chevy; 05-14-2018 at 07:57 PM. |
05-14-2018, 10:05 AM | #6 | |
I don't know where triple pass came from, but you've convinced me. I'm calling it a two pass or double pass from now on!
Thread Tools | |
Display Modes | |
