![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Drum to disk from a donor truck. What parts?
My buddy has an 8 lug front disk truck and I have a 4 drum 8 lug truck. Hes hooking me up with the front disk and parts.
What all do I need to put the front disk setup on my truck?? Thanks. |
#2 | |
Re: Drum to disk from a donor truck. What parts?
What year are both trucks?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Best scenario: park the donor next to the donee.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
![]() Join Date: Mar 2011
take the MC and the proportion valve and the whole front crossmember out do a complete swap brake lines an all ......trust me that the easier way
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
I took the whole front crossmember except the crossmember itself, if that makes sense. In other words, everything attached to suspension and crosssmember except the crossmember.
And if you've got room, by all means, take the crossmember!
x2 what he said take it all.....
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 05-20-2018 at 08:00 AM. Reason: more info |
Is swapping the whole cross member still the way to go if you are changing spindles?
I'm in the same boat but doing drop spindles also. |
now thats not just a yes or no answer what year? are you doing drum to disc? ball joints are not all the same
I have a 69 C20. Picked up a 71 C20 front end. Was going to swap it but I am rethinking that. Seems like I could do the tie rod and ball joints while I have the 69 apart and not do the full swap.
yes sir much easier .....
#13 |
Easier to NOT do full swap? I am leaning that way since I am taking so much apart to do spindles anyway.
#14 |
well you have 6 grade 5s on each side of the engine cradle( if my memorey is right) and that will seperate it from the frame take lots of pictures of brake lines and anything you may be changing beteween the years .....brake lines are different 71-72 vs 70 and down brackets that hold the rubber brake lines are on the front of a 71-72 on the back of other years brake lines up to Master are different too
#15 |
Makes sense. Sorry for the hijack.
Thread Tools | |
Display Modes | |
