[Pic] Hmm..I think I need an alignment
What would you say, do I need an alignment?
I would say you need a tire first, then get it aligned
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
#3 | |
Professional Grade
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Project92 SWB stepside
Me to!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
STILL PLAYS WITH TRUX
Worn out shock absorbers can cause that type of wear too.
Happy to be here
![]() Join Date: Mar 2000
Yes, you do. You also need a tire, as mentioned by the others, and you need your suspension repaired.
Stylin
ok had the same problem. could be a number of things, shock absorbers like 87stepper said, mine were the lower ball joints. i think it would be a good time to replace the upper and lower ball joints and tie rods then get the alignment done. and shop around for some new shocks also just my 2 cents also thats not as bad as i did when i checked my tires i had worn past the metal on the tire lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
I see a PST kit coming soon. I want one so I can get mine aligned.
Tim, are you ever going to get that piece running and dependable? seems like there's always something going worng with it.
#10 | |
Trucker.
#11 | |
BUT, back on topic... My truck is running perfectly fine finally...*knock on wood*. I found out that I"m leaking out of the front of the oil pan, so it goes back in the shop that built the motor for a free fix. ![]() BTW: The TRUCK'S suspension is perfect as can be..except for the fact it's TOO stiff, and TOO light. ![]() |
Stylin
haha ive seen tires like that on trucks before lol
#13 | |
#14 | |
Under construction!
And not bagged.....:p
2001 Silverado bagged on 22's. *Sold* |
Thread Tools | |
Display Modes | |
