View Poll Results: Anti Corrision Inhibitors | |||
Purple Ice |
3 | 60.00% |
Water Wetter |
2 | 40.00% |
Voters: 5. You may not vote on this poll |
![]() Join Date: Jul 2015
Coolant Anti Corrsion Inhibitors
After doing some reasearch I came accross 2 big names in the mass market. May turn this into a poll.
Which one is better? Redline's Water Wetter Royal Purple's Purple Ice Lets hear it for the votes. And specifically why? |
Re: Coolant Anti Corrsion Inhibitors
Drag racing community around here go Royal Purple.
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car. 1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof. |
Keeping it fresh, found some stuff at NAPA and had used it before called NapaKool.
Appears to have a 2 percent Hydrochloric Acid in Solution with Nitrates and Nitrites. So who can speak to block corrosion and prevention using these products. |
I use the NAPA stuff on the fleet vehicles I maintain. I also use their coolant test strips to test, once a year.
Not sure what those others do, or what they are. The NAPA product is made for the common coolants that have been around for a long time. |
I've used the water-wetter before several times.
I can't say if it made a difference or not. If I recall corectly, it is like $18 a bottle at my o'reillies or autozone. |
some contents increase thermal transmission, other resist rust, others remove rust and scales.
flush it, remove scales and rust, add a proper mix with a water wetting agent. In the pontiac community I hear water wetter is good, After flushing a system I have used CLR or Drano to remove any grease, stop leak, rust or what ever from the system. Drano will damage water pump seals and aluminum. then a 50/50 mix Drano will find any leaks. Dont blame it if your cooling system was about to take a &4#@) any way. Flush it out thoroughly or it will keep on working. |
#7 | |
Anyone have better luck? |
Thread Tools | |
Display Modes | |
