06-19-2018, 07:08 PM | #1 |
Th-350 Kickdown Install Help
Just Wondering How I Go About Installing a Kickdown on A Th350 and Adjusting It? Thanks
Posted via Mobile Device |
06-19-2018, 11:46 PM | #2 |
Who Changed This?
Re: Th-350 Kickdown Install Help
What do you have, now? You put in a 350 trans as an upgrade, or what? More info is needed. Is there a detent cable installed? Is the bracket there for the detent cable to mount to on the intake manifold? Is there a provision on the throttle linkage for the detent cable? Show us pics of your setup.
06-20-2018, 12:47 AM | #3 |
I'm Using a lokar Setup. The truck came With The Transmission. I purchased The brackets Lokar recommened. It Has A spring Tab In The Hole Where The Kickdown Goes. I will post pics tmrw. Thanks
06-20-2018, 11:45 AM | #4 |
You should have these...
http://www.lokar.com/assets/instruct...ickdownKit.pdf Step 11: Slide the kickdown cable end stop onto the inner wire. Move the throttle to wide open and hold it there while pulling the kickdown inner wire as tight as possible. Slide the cable end stop up against the kickdown throttle body fitting and tighten the set screw using the supplied 5/64" Allen wrench. Release the throttle. When the Kickdown Cable is properly adjusted you should be able to open the throttle to the wide open position without interference from the Kickdown Cable; and with the throttle wide open, you should not be able to pull the Kickdown Cable out any further.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Thread Tools | |
Display Modes | |
