08-16-2018, 07:31 AM | #1 |
Rams Horns on TPI pix
If anyone has Rams Horns manifolds (esp chrome) fitted to a 350 TPI in their 60-66 could you please post some pictures?
I would appreciate a look before ordering. Thanks |
08-16-2018, 11:12 AM | #2 |
Moderator
Re: Rams Horns on TPI pix
08-16-2018, 11:50 PM | #3 |
60-66 Nut
I don't think the issue has anything to do with a TPI but more of the center bolt valve covers? I could be wrong on the valve covers but it seems like I have heard that there is an interference issue with ram horn manifolds.
Edit: Here is some info I found on the subject. https://www.hotrodders.com/forum/ram...rs-181741.html
08-17-2018, 06:47 PM | #4 |
Thanks for the feedback.
08-18-2018, 08:48 AM | #5 |
hello I don't have pics but on my 57 wagon I used the rams horn with center bolt covers and had no clearance issues..close but no issues....but take in mind my manifolds were uncut...if the mounting surface had been resurfaced a couple times the manifold could touch the VC...gaskets will give a little clearance..Good luck!
08-18-2018, 09:15 AM | #6 |
I had a set on my tbi motor in the 63, not much clearance as mentioned above. I ended up buying a $150 set of headers for an 88-98 that use the stock y-pipe for the same truck. They fit perfect, clear the frame with no grinding, and flow much better. It was a marked improvement. I'll get pics in a few minutes.
08-18-2018, 09:01 PM | #7 | |
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
08-19-2018, 01:09 AM | #8 |
60-66 Nut
This style of rams horn manifolds will fit with plenty of clearance.
https://www.speedwaymotors.com/Tru-R...Iron,3823.html
08-19-2018, 01:28 AM | #9 | |
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
10-01-2018, 09:55 PM | #10 |
After much investigation it seems that most Rams Horns that I have seen on the market are identical and are made in PRC.
Design, markings and finish all appear to be same to me. I bit the bullet and bought a set and am happy to say that they fit well with center bolt valve covers with about 1/4" clearance between the cover edge and top of the manifold. For added clearance I used a one piece gasket in addition to the the 3 individual gaskets that the Horns came with. I don't foresee any issues, but time will tell. Thanks to all who showed interest and gave input. |
10-02-2018, 12:32 AM | #11 |
60-66 Nut
Thank you for taking the time to post your findings. It will surely help someone in the future with the same question.
10-02-2018, 03:00 PM | #12 |
I wish I used these on my last build. I used street rod headers and had a pain relocating the knock sensor for clearance
65 short step edited by staff |
Thread Tools | |
Display Modes | |
