Old 09-05-2018, 03:55 PM   #1
72timemachine
Can I machine down some van axles to fit?
I can lay my hands on some free rear axles out of a '72 1/2 ton, GMC Vandura which has a small block v-8 and th350. They have a spline count of 30, are 33 3/8" long and are a 5 on 5 lug pattern. I found this information on a website and am not sure if it is accurate.
I would like to try and have them shortened if possible to fit a '69 c10 rear end, which currently has an axle spline count of 30, are 30 3/4" with a 6 lug pattern. I do not feel the 6 lug can be re-drilled to locate a 5 on 5 lug pattern due to the larger hub in the center which will not allow my stock rim to fit.
Do you feel this is too expensive a venture? The axles are free. The cheapest kit I can find is upward of $280 for axles, bearings, seals and lug studs. I would also have to get new drums as they do not come with the kit.
Anyone ever shortened a rear end, the difference, if my math is correct is 2 5/8" between the 5 lug van axle and my 6 lug axle.
Thanks for any advice.
72timemachine is offline   Reply With Quote
Old 09-05-2018, 04:54 PM   #2
Coley
Coley's Avatar
Re: Can I machine down some van axles to fit?
What do you expect to pay to have them professionally shortened?....do you have a buddy with a machine shop and who welds who you can trade some stuff for?
That isn't necessarily quick work if it is to be done correctly and shop rates for qualified machinists aren't free these days.
To be honest, the $280 kit sounds more economical and a lot less hassle and worry to me..
my two bits..
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-05-2018, 09:03 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I used the Moser 5 lug conversion axles when I went to 5 lug in a 1969 C10 housing. $265 bucks shipped to my door from Summit Racing. EZPZ install.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-08-2018, 05:19 PM   #4
72timemachine
Update:
After talking with a few area machine shops, it can be done, it's just the labor rate is just about equal to buying a conversion kit, also bear in mind, the axles were free, that was my only reason for asking members here in the forum is they have ever tried to do something such as this.
If you do happen to know a machinist and you can work out something in a trade for his labor or you live in a region of the country where labor rates may not be as high as the ones here in California, it could still be worth looking into.
Thread Tools
Display Modes
