Old 09-19-2018, 12:24 PM   #1
OregonNed
OregonNed's Avatar
Lookin for input on ‘68 side trim
I’m looking for input on those who have used the 3M automotive trim tape to attach their side trim pieces. Specifically, I am looking for the size of tape width-wise and maybe a picture or two if anyone has any of the back side of the trim where they affixed the tape. Thanks so much. Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-20-2018, 07:17 AM   #2
plowro8
Re: Lookin for input on ‘68 side trim
I don't have any pics of the process, but I used this tape on my truck and I am very happy with it. You might have to double or triple it up in areas to keep it hidden within the trim and still have it be able to reach the body of the truck, but it works well, and It sure does beat drilling holes if you don't have the original holes in the body any longer.
I just put a few pieces of the tape every 8-10 inches, didn't need to tape the whole thing.
plowro8 is offline   Reply With Quote
Old 09-20-2018, 07:19 AM   #3
plowro8
Trim held on with only tape
Old 09-20-2018, 10:33 AM   #4
OregonNed
OregonNed's Avatar
Thank you! Another member did his trim the same way on his '68 - and it worked well. I appreciate the information. This morning I found an old email from him describing what he did in regards to applying the tape. It took a bit, but I was finally able to get a description of the trim backside. All photos show the front only... Ned
Old 09-20-2018, 10:33 AM   #5
OregonNed
OregonNed's Avatar
Nice looking truck by the way!
Old 09-20-2018, 01:28 PM   #6
Custom 68
Custom 68's Avatar
I am not sure how well this will work on the 68 specific trim. Since it is aluminum and there is spacing on the back side for the clips That flat part does not sit on the body. I suppose you could build it up some maybe.
I did use the tape on my emblems but I filled the back side with epoxy then taped it on. I did leave the studs for location but couldn't easily get to the back.
Just my thoughts.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-20-2018, 04:00 PM   #7
OregonNed
OregonNed's Avatar
I may have to end up drilling it all but looking for options hopefully. The other ‘68 owner put the 3M tape on the back top and bottom of the trim pieces (narrow) and it worked well. I probably won’t know for sure until I pull
The trigger and purchase the trim.
Thread Tools
Display Modes
