Putting a late 50's 235 in a 48 truck.
Ok, something hit me as I am getting this rad support set up, my trucks rad was moved forward and now I am getting memories of a short waterpump needed on the 235 to go in the earlier truck, is this right?
Can the later 235 go into my 48 (with a 50ish rad support) with the rad bolted into the stock location? Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Re: Putting a late 50's 235 in a 48 truck.
I have a '59 235 in my '47 second series. The water pump has a short shaft and modified pulley. The radiator is mounted forward. There is plenty of room between the fan and radiator. Enough room that I could probably use a stock water pump, or move the radiator back. You might want to get the engine in place before setting up the radiator support.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
I need to nail this down because I want to mount my rad support once, but now I am seeing that may not be possible. It kills me because I forgot this and have a new pulley and pump, crap.
Brian
If I'm not mistaken, you need the correct crank pulley too. If you do a you tube search, you can find a guy that pressed the hub down on the water pump to make it into a short one.
Thread Tools | |
Display Modes | |
