10-07-2018, 05:04 PM | #1 |
Wheel spacers
I would like to space out my rear tires about 1/8 of an inch so that my tires don’t rub on the inside of wheel wells. Would it be possible to use washers on each lug or should I look for a 1/8 inch wheel spacer? It only rubs when turning into driveways so I figure it is barely rubbing
10-07-2018, 05:51 PM | #2 |
Moderator
Re: Wheel spacers
I'd go with the spacer and not the washers. Spreads pressure out instead of in little spots.
10-09-2018, 04:16 PM | #3 |
Re: Wheel spacers
So I can only find 1/4 inch and thicker 6X5.5 lug spacers. What are my options other than milling down the a 1/4 inch spacer to 1/8 inch.
10-09-2018, 05:25 PM | #4 |
Check The Champ, Demonstrator
Re: Wheel spacers
1/8 plate. Drill holes using an old wheel as a template.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
10-09-2018, 05:38 PM | #5 |
Re: Wheel spacers
10-09-2018, 05:58 PM | #6 |
Re: Wheel spacers
Jigsaw works.
That’s what I used to make this oval air cleaner. |
10-09-2018, 06:07 PM | #7 |
Re: Wheel spacers
What material should I use? I think the 1/4 in spacer that I have is aluminum.
10-09-2018, 06:41 PM | #8 |
Re: Wheel spacers
Use aluminum.
Metal supermarkets should have sheets of it. Sometimes you can find some in the hardware store. |
10-09-2018, 06:44 PM | #9 |
Re: Wheel spacers
Aluminum would be great. You can use wood working blades on a jigsaw to cut. General rule of thumb 3 teeth touching metal at all times. Lubricate while cutting or drilling. Milk or cream was a household solution. Holesaw for center bore , can be larger than wheel bore it doesn't matter. Save the wheel by cutting down an old drill bit to scribe stud hole centers then come back with a 1/2" if you have stock studs. The oversize holes will allow a little play. Paint can could be a close diameter for drawing circle or steal the kids compass for more refined results with a starting center point.
10-09-2018, 06:48 PM | #10 |
Re: Wheel spacers
thanks I will give it a try.
10-09-2018, 07:12 PM | #11 |
Moderator
Re: Wheel spacers
You check ebay? I got 3mm spacers on there, 6061 billet.
10-09-2018, 09:09 PM | #12 |
Re: Wheel spacers
A proper wheel mount should use a combination of sheer and capture around the axle that protrudes out of the drum. If you are building a spacer that moves the wheel load to just sheer on the studs you could have some issues. Also a proper wheel spacer is balanced.
Thread Tools | |
Display Modes | |
