Old 10-31-2018, 08:25 PM   #1
18Z
18Z's Avatar
Transfer case crossmember position
I forgot to mark the front of the transfer case crossmember when I took it off, is there a front and rear to it or can it go in on either side?
18Z is offline   Reply With Quote
Old 10-31-2018, 10:11 PM   #2
kwmech
Re: Transfer case crossmember position
The cross member usually has some 3/8'' holes the flat place for a skid plate, those are on the right hand side. there are 4 of them
Old 11-02-2018, 10:17 PM   #3
18Z
18Z's Avatar
I will check thanks!
Old 11-03-2018, 03:26 AM   #4
jeffahart
jeffahart's Avatar
Who knows what you are running. Here's the blinders response, along with what's been pointed out. Assemble with original mounts. If you get poly adapter mounts to the cross member it could, not for sure but could, kick your angle off as much at 2 degrees. Assemble with original rubber mounts. Recheck angles. If all angles are good and no vibrations then move forward with new mounts. The poly stuff is unforgiving and will magnify the drive-line imperfections. I have a love hate relation with the new non rubber bushings and such.
j
White K20
jeffahart is offline   Reply With Quote
Old 11-10-2018, 11:22 AM   #5
18Z
18Z's Avatar
Here is a picture of it.
Old 11-10-2018, 11:25 AM   #6
18Z
18Z's Avatar
I have some NOS rubber for the side bracket that attaches to the T case. Truck has a SBC 350 with a Turbo 350 trans.
Old 11-11-2018, 12:46 AM   #7
kwmech
The holes I was talking about are not in that member, but looking at the pic, it may not matter. Take some measurements from the large holes to the end holes and see if they are centered
Thread Tools
Display Modes
