11-02-2018, 03:51 PM | #1 |
Motor mounts
I'm going to have to show my lack of knowledge on these trucks for a min. Looking at the stock motor mount perches there is only one bolt hole in the middle for the mount. Is there a bracket or something like that that bolts to it to attach the mount to?
11-02-2018, 09:35 PM | #2 |
Re: Motor mounts
How about some pictures. Also, what motor are you putting in? There are many variables involved.
11-02-2018, 11:33 PM | #3 |
60-66 Nut
Re: Motor mounts
No, there is no bracket needed. The '63-'72 small block and I6 engine mounts have a threaded hole in the center. A 7/16-20 bolt passes thru the hole in the engine mount bracket and threads into the engine mount which is bolted to the side of the block on a small block. On the I6 engines, there is an additional bracket that bolts to the side of those blocks which the engine mount bolts to.
https://www.classicparts.com/1963-72...info/79%2D021/ The number 2282 is the same part number used by most all manufacturers of these engine mounts. You can also purchase them at your local auto parts supplier.
11-02-2018, 11:53 PM | #4 |
Re: Motor mounts
Thanks Cap. I can always count on you and that fountain of knowledge you have. Oh and BTW for anyone reading this, the brackets and adaptors I have gotten from Captain Fan are second to none and some of the only parts I have gotten that needed no "tweaking " to work.
11-03-2018, 01:38 PM | #5 |
Re: Motor mounts
I guess I just showed my lack of knowledge...lol
Thread Tools | |
Display Modes | |
