Old 11-06-2018, 12:15 AM   #1
1G1YY
Need measurement help 62 SWB..
I am trying to set up pinion angles using a T700 on a rolling chassis without any bodywork.
I will be fitting 4" drop coils in back.
I need to know the distance from ground to rear of lower part of chassis on a step with 235/75-15 wheels, as I note that there is a 3 degree variation of the rear end output shaft angle from from full compression to full extension.
If a member has a short stepside with 4" drop coils and could give me this measurement I would be grateful, so I can set that height on my chassis to get the rear end output shaft angle under normal ride height.
I am assuming the rear angle should be about 4 degrees but want to be sure before fabricating mounts for a Corvette C4 T700R4.
Thanks to those that can help with this..
1G1YY is offline   Reply With Quote
Old 11-08-2018, 07:20 AM   #2
1G1YY
Re: Need measurement help 62 SWB..
Ttt
Thread Tools
Display Modes
