Old 11-11-2018, 12:13 AM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Who sells these pieces??
Did some cutting and here's what I found....or I should say what the shop found. Looks like the truck is gonna need bottom portion of the pillar and that flat piece between the fender and cab. Thanks.
desert-rat is offline   Reply With Quote
Old 11-11-2018, 12:18 AM   #2
desert-rat
Re: Who sells these pieces??
Sorry if the pictures came out sideways.
Old 11-11-2018, 01:10 AM   #3
FL71C10
The first picture is the a-pillar. The second one looks like the bottom of the cowl. I know the a-pillar is available from triplus. Try Top Banana or gmcpauls I'm pretty sure the other piece is available as well but I'm not sure
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-11-2018, 01:10 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I flipped them. I know the lower pillar/cab pieces are made so you should be able to get those from any parts vendor. The other piece looks to be the lower rear fender brace and should be fairly easy to make if none of the parts vendors have it.
Have a look at this thread, post #9.
http://67-72chevytrucks.com/vboard/s...d.php?t=462470
Edit: After reading FL71C10's post and looking at the picture again the second picture does look like the bottom of the cowl/firewall fresh air box.
LockDoc
Leon
Thread Tools
Display Modes
