Old 11-17-2018, 03:14 PM   #1
Greasey Harley
Greasey Harley's Avatar
New clutch doesn't work
I blew up my clutch in my '68 c10 this summer (kuz I got a lead foot)
I let it set around and finally got around to putting a clutch in it this week.
Put a Rhino pac diaphragm style, stock clutch in it. hooked everything up and the clutch just isn't there. almost no resistance, pedal goes right to the floor.
Can't adjust it any further. Something is definitely wrong.
everything seems to be installed properly. This is about my 20th clutch swap (not all on the same truck), first major problem I've ever had.
Any guesses? Thoughts,
I'm about to go back out there and re-remove the engine and take a closer look.
Pretty simple unit, I can't imagine what I might be missing.
Has to be one of three things
1: Wrong clutch kit
2: Defective parts
3: Improper installation
-Russ
Greasey Harley is offline   Reply With Quote
Old 11-17-2018, 04:00 PM   #2
geezer#99
geezer#99's Avatar
Re: New clutch doesn't work
Wrong throw out bearing!
Is it a flat or raised finger pressure plate?
Old 11-17-2018, 04:03 PM   #3
Shinysideup
Shinysideup's Avatar
I would think crawling back under there and proper visual inspection of throw-out bearing, clutch arm, and linkages will show you where it doesnt work.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 11-17-2018, 05:43 PM   #4
Greasey Harley
I an leaning toward this. My buddy, Randy is going to come have a look before I tear it apart again. He has worked in transmission shops for 40 odd years. He also suspects a short throw out bearing where there should be a long one.
Old 11-17-2018, 05:45 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
1. There are 3 different height throwout bearings for diaphragm style chevy clutches.
2. A common error is to install the fork incorrectly...
see this link as it shows it all in one post...
http://garage.grumpysperformance.com...-bearing.6258/
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-21-2018, 01:58 PM   #6
Greasey Harley
Originally Posted by Greasey Harley View Post
I blew up my clutch in my '68 c10 this summer (kuz I got a lead foot)....
.... Pretty simple unit, I can't imagine what I might be missing.
1: Wrong clutch kit
2: Defective parts
-Russ
Update:
I was sippin' on beer , cleaning up the shop this weekend , just staring down my truck, one thing let to another and I started ripping it back apart. I don't normally turn wrenches while intoxicated, but I was PO'ed and annoyed, so I did.
I tore the linkage apart, inspected it, with one eye closed, so I could focus. In my enhanced state, I couldn't find anything wrong with the apparatus.
It dawned on me that I was in no condition to R&R a clutch, so I did the only sensible thing; I drank a couple more beers and proceed to reassemble the clutch linkage.
That's where it gets weird.
I slammed the whole thing back together, using the exact same parts, and it worked perfectly. WTF?
I have no idea how or why. I was careful and SOBER when I first put it together, I was basically $#!tfaced when I reassembled it this time.
All I did was disassemble then reassemble the linkage.
Granted, being a 50 year old truck, the linkage is rather sloppy, but it works as well I have ever seen.
I have gone back over that thing multiple times (while sober), I have NO IDEA why it didn't work the first time, nor am I sure what changed to make it work now.
-Russ
Old 11-21-2018, 02:23 PM   #7
Redneck Rydes
Redneck Rydes's Avatar
I have had the same problem with putting things back together,No Beer, doesn't work,sit back in my chair drink 5 beers,go at it again, works just fine, beer make things clearer.LOL
Redneck Rydes is offline   Reply With Quote
Old 11-21-2018, 05:59 PM   #8
jeffahart
jeffahart's Avatar
Maybe you had it installed with the rod in the outer hole of the fork and reassembled it with it in the inner hole. The pedal spring will give enough tension to fake you out a bit. Possibly!
Drinking and wrenching is a sport for me!
j
White K20
jeffahart is offline   Reply With Quote
Old 11-21-2018, 07:21 PM   #9
flashed
I wonder if I started Drinking I might start working on my trucks ?
flashed is offline   Reply With Quote
Old 11-21-2018, 07:21 PM   #10
Grumpy old man
Grumpy old man's Avatar
Beer makes you smart ...It made Bud weiser
My friend and I were at the local pub drinking the other night. I looked over and said, "Hey man, look at those two old drunk bas-ards over there. That'll be us in a few more years". He glanced over, looked at me and said "You drunk idiot, that's a mirror!"
A man walks into a bar and up to the counter. The bartender asks him, "what can I get for you today." The man replies, "I'll take three glasses of your most rare bourbon barrel aged russian imperial stout." As fast as the bartender was pouring the man was downing the beers even faster one after another. Stunned the bartender asks, "I've never seen anyone drink that fast before." "You'd drink that fast if you had what I had," said the man. "What do you have," asks the bartender. Turning around the man replies, "fifty cents."
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 11-21-2018, 07:51 PM   #11
flashed
Lol.
Old 11-25-2018, 08:24 PM   #12
El Dorado Jim
El Dorado Jim is offline   Reply With Quote
Old 11-26-2018, 09:29 AM   #13
panhead59
And to imagine they call you Grumpy !
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 11-26-2018, 09:45 AM   #14
Grumpy old man
The millennials call me Grumpy ,Even my own kids , The old guy's consider me Normal ? Ok , Maybe just a few do ...Alright , one or two do ....Never mind ....
Old 11-26-2018, 10:21 PM   #15
AussieinNC
Moderator
AussieinNC's Avatar
You are totally normal Grumpy....ya have to be to be such a great source of knowledge and humor....
Beer keeps me sane...
Stay warm young man...
2012 Chevy Equinox
Old 11-26-2018, 10:33 PM   #16
jeffahart
jeffahart's Avatar
Good one!
White K20
Thread Tools
Display Modes
