11-20-2018, 12:10 PM | #1 |
3 on the Tree Truck
Happy Thanksgiving everyone, just have a quick question.
My 65 is a 3 on the tree truck and I will never get rid of the three, I love it! But what I hate is only going 55mph, so the highways out here are off limits. I was curious what rear end gears others are running to allow more of a highway driveability. Thanks, everyone. |
11-20-2018, 12:53 PM | #2 |
Re: 3 on the Tree Truck
You actually have 2 options to keep the 3OTT.
1) Switch your rear gears to something like a 3.08 or something around there 2) Swap the regular 3OTT for a 3OTT with Overdrive. It shifts the same as a straight drive trans, but there is a borg-warner electronically controlled overdrive that takes place of the regular tail shaft My truck originally had the overdrive trans, but the previous owner removed it many years ago. I like having a 3.73 rear, so I'm going to go with an overdrive trans
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-20-2018, 01:04 PM | #3 | |
Anyone running a 3.08 with a 3 on the tree? Just curious how sluggish it is from 2nd to 3rd, and the cruising RPM on the highway. |
11-21-2018, 11:27 AM | #4 | |
11-21-2018, 01:44 PM | #5 |
Back in the early 80s a bud of mine asked me to help him install a Saganaw 4 speed in his truck. It was 3 on the tree also. Weren't no problem, popped right in & all we had to do was change the yoke & a little linkage mod.
The trans didn't come with a shifter, the old trans was jumping 3rd & he couldn't afford to buy a shifter so that's why the column shift 4 sd! It was during these linkage mods that it occurred to us that there was no provision on the column shift for reverse! But it was late & he drove it home shifting on the column. He later either used a pull in solenoid or a cable for reverse, can't remember. But anyway the trans had such a low 1st gear it almost was like an Sm465 taking off in low! 3.11 I think... Later we installed a rear axle assy from a later truck with 2.73 gears. That trans pulled the 2.73s just fine & the little 283 had no problem clipping along at 75! It did it so well that he got NUMEROUS tickets in that old 67! |
11-21-2018, 07:15 PM | #6 | |
11-21-2018, 01:39 PM | #7 | |
I found mine on ebay that was rebuilt and has the electronics and an old harness. $700 search this site. A few guys have made their own harness on the cheap and newer parts.
--Life looks better through a curved windshield-- |
11-20-2018, 03:45 PM | #8 |
What would the transmission be worth 3 speed with over drive?
11-20-2018, 04:37 PM | #9 |
The worth depends on what the owner is willing to sell it for and what the buyer is willing to pay. I've seen them go anywhere from 200 to 500 bucks. I have only seen 1 of these in person though.
You also have to factor in the other components such as the kickdown switch and relay and wiring if you want it to operate as GM intended
11-20-2018, 04:41 PM | #10 | |
11-20-2018, 04:45 PM | #11 | |
11-20-2018, 04:05 PM | #12 |
Moderator
I wonder if a truck is different? - https://www.ebay.com/itm/Manual-Tran...IDX:rk:16:pf:0
11-20-2018, 04:42 PM | #13 | |
Here is a sm319 (has overdrive) https://www.ebay.com/itm/1955-thru-6...mZR1:rk:2:pf:0 As far as I know, the only difference between the cars and the trucks are how the shift arms connect. The earlier year transmissions do not have a tailshaft mount cast in, but the later years do. For our trucks, you could get either year range trans
11-20-2018, 04:45 PM | #14 | |
this is the one I saw yesterday..I remember thinking that it looked like it had an il filler neck on the side...Wasn't really interested as I put a 700R4 in my truck but when I saw this thread it made me wonder. |
11-22-2018, 01:25 AM | #15 |
You can wire the overdrive trans up not needing engagement cable or foot switch. My installation in 63 C10 went like this:
Used side plate (4-bolt) and shift arms off original three speed. This allowed the use of stock shift linkage arms. Wired with toggle cut off / cut on switch for solenoid. Now when I want overdrive, flip the switch to on, accelerate to about 30MPH, let off gas and she shifts into OD. There is a thread with lots of information and pictures. I tried to copy thread below but not sure I did it right but you can search on "3 Speed Overdrive" and the post you want is "3 Speed Overdrive, Now about getting it it" http://67-72chevytrucks.com/vboard/s...d.php?t=313886 |
11-23-2018, 12:47 PM | #16 |
11-25-2018, 10:48 PM | #17 |
Have you looked at Gear Vendors Overdrive? They aren't cheap, but if you're hell bent on keeping the 3OTT they might be another option. I never cared for the 3OTT, especially if it didn't have a syncro for first, but it's definitely got a certain amount of cool factor.
Thread Tools | |
Display Modes | |
