Old 12-05-2018, 10:25 PM   #1
SunSoaked
SunSoaked's Avatar
Auto Dimming Mirror Upgrade
As many of you know, I recently broke my windshield. Additionally, I've had the rearview mirror fall off twice taking chunks of glass with it. So tomorrow I'm getting the windshield replaced. Today I went to the junkyard and pulled the mirror and temp sensor off a 2001 Silverado. Paid a whopping $35 for everything including the harness. Only 5 wires to make this work and I get LCD temp, compass and ice warning. Bench test verified everything works. Excellent mod for the $.
SunSoaked is offline   Reply With Quote
Old 12-06-2018, 07:49 AM   #2
homemade87
Re: Auto Dimming Mirror Upgrade
I have one in my 82 . I got it from a 04 truck I bought for my ls swap . Works pretty good . Easy install as well with a stand alone harness .
homemade87 is offline   Reply With Quote
Old 12-06-2018, 08:06 AM   #3
jjzepplin
jjzepplin's Avatar
Great idea! I wonder what mirror is in my 99 TA donor vehicle. Where will you route the wires? I don't have a Headliner in my truck. Guess I might need one.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-06-2018, 08:12 AM   #4
homemade87
Mine did have the headliner in it so was not a problem . Even if you drilled a hole I am not sure the front post would accept the wire going down . I know the rear post would . Just longer wires to get there if you did not want a headliner .
Old 12-06-2018, 09:27 AM   #5
Rich84
Rich84's Avatar
My wife just grabbed my mirror to fix her hair or something and ripped my mirror off. It left me with a small crack in the glass where the base was glued. I want one of these...Would love to see a how to. I have no headliner.
Rich84 is online now   Reply With Quote
Old 12-06-2018, 09:34 AM   #6
MalibuSSwagon
I have one as well, from a 98 Old Intrigue GLS. These were unique for that specific car as they had LED dome lights built in. Will be nice as I don't have a dome light in my truck. I also do not have a headliner, so been looking around for a way to hide the wires. Was thinking some sort of conduit?
MalibuSSwagon is offline   Reply With Quote
Old 12-06-2018, 09:49 AM   #7
SunSoaked
SunSoaked's Avatar
I'll have the install done over the weekend. I'll take pics of how I did it and post here. I'm getting the new glass in a few hours.
The 90's trucks are good donors. I saw several 99-05 models that had them. Look for ones with a 7 cavity plug (mine only used 5 of the 7 ports). Remove the mirror with a star driver. Pull the harness out from behind the headliner. Some of them have legs going to the visors if they are lighted.
Make sure you get the temp probe if you want that function. It's located behind, below and near the front bumper. It's two wires. They will be black/white and a green/white.
The other 3 wires are pink=ign, black=ground & green=reverse light. The reverse function just shuts off the auto-dimming in reverse. You don't have to use it if you don't want to.
I'm running my wires thru the roof and down the B-Pillar and back up to the fuse panel. You can access and fish the wires thru the hole where the visor mounts.
I tried for hours to get wire thru my A-Pillar with no luck.
You will also need the correct button that glues on the glass, it's different than what you have.
Stay tuned for pics and more details.
Old 12-06-2018, 09:53 AM   #8
SunSoaked
SunSoaked's Avatar
Run wires inside the roof. I don't have a headliner either. I drilled a 1/4" hole near the mirror base and ran the wires thru there. I don't mind seeing a few inches of wire. Don't forget the grommet.
Old 12-06-2018, 11:23 AM   #9
cadillac_al
I have those auto dumb mirrors in some of my vehicles and I usually wish I just had a button to flip. I don't think they work as good as an old mirror. It would be downgrade for me.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-06-2018, 11:55 AM   #10
hatzie
Moderator
hatzie's Avatar
Yup.
The sheet metal you see is not the outer roof skin. Just be careful not to drill through both...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-06-2018, 02:54 PM   #11
SunSoaked
SunSoaked's Avatar
And keep your knee off the windshield (don't ask!) or you'll end up with this...the mistake that started the whole thing.
Old 12-06-2018, 04:23 PM   #12
focusedontheprize
focusedontheprize's Avatar
Thanks for doing this SunSoaked. I would like to do this upgrade to my C30 and this will be a huge help.
focusedontheprize is offline   Reply With Quote
Old 12-06-2018, 06:29 PM   #13
hatzie
Moderator
hatzie's Avatar
That sinking feeling when you know you'll be buying a new windshield.
The roof marker lamps run up the A pillar and across the front of the roof between the skins. You should be able to run the mirror wiring the same way.
The dome wiring runs through the back corner of the cab and up the pillar behind the door. Not a big deal to add those.
If you're going to have the mirror lights run as the dome... the wire at the headlamp switch is the ground not the hot wire. The stock dome gets power all the time.
Must be someone absconded with his dome lamp. My 85 base model Custom Deluxe had a dome lamp and it only had a few options on the short SPID... the 305 V8 engine, gauges, and 4 speed manual. My 74 had one too and that was a real stripped down base model truck with manual brakes, idiot lamps, three on the tree, Inline 6 and radio delete.
If you look in the 1991 & 1990 wiring diagrams GM was kind enough to put in some routing diagrams.
Old 12-07-2018, 11:53 AM   #14
Rich84
Rich84's Avatar
My stripped 84 has one.. 86 with a/c does not. Weird.
Old 12-09-2018, 10:47 PM   #15
SunSoaked
SunSoaked's Avatar
Finished!
Killed two birds with one stone. Got the glass replaced and swapped in an auto-dimming mirror from an 01 Silverado in the process. And... installed my "moonvisor" and ran the wires for the running lights all at the same time.
To the point- I ran the 5 small wires (20 guage maybe?) thru a piece of vacuum hose into the roof thru a 7/16th hole. From there it goes to the driver side A-Pillar where it joins the two wires for the running lights. Then back to the B-Pillar and down the chute and under the door sill and weather strip up to the fuse panel for. The two wires for the temp sender go up front behind the bumper away from engine heat.
Easy peasy! I'm really pleased with the visor and mirror. Visor from Summit Racing ($199) mirror from junkyard ($35).
Thread Tools
Display Modes
