Old 01-27-2019, 09:34 PM   #1
Big70
Taking apart a short box
I just want to make sure before I buy this short box of this guy.... all the panels on a short bed fleet side unbolt so I can just bolt on a new panel that’s dented with out cutting and welding? I’m going to cut my lwb 70 down to a Swb and about to guy this bed off this guy but I needs a new driver side in the bed...
Big70 is offline   Reply With Quote
Old 01-27-2019, 09:53 PM   #2
flashed
Re: Taking apart a short box
They do unbolt but there is a stitch weld near the rear on each side to grind out .
flashed is offline   Reply With Quote
Old 01-27-2019, 11:00 PM   #3
Big70
D
Do I need to re weld it after I bolt on a new panel? Where is that weld at?
Old 01-27-2019, 11:02 PM   #4
Andyking1203
Originally Posted by Big70 View Post
D
The weld is right next to the rear stake pocket, I'd suggest reselling it!!
Andyking1203 is offline   Reply With Quote
Old 01-27-2019, 11:18 PM   #5
Big70
I’m sorry I don’t know where that is what it looks like I don’t have my truck here is there any way you can show in a pic?
Old 01-27-2019, 11:25 PM   #6
flashed
It is in the corner of the bed stake pocket at the bed floor on each side , can be ground out with an 4" angle grinder . With all the bolts back in place I would not worry about rewelding it .
Old 01-27-2019, 11:53 PM   #7
rjs53
Its a small weld you might see when dropping the tail gate. It may have cracked after all these years. If you don't see it when you get all the bolts out, the back corner might seem stuck but its probably the weld.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-28-2019, 01:36 AM   #8
70LonghornCST
Moderator
70LonghornCST's Avatar
Here you go:
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Thread Tools
Display Modes
