S10 conversion header question
Believe me, I think Iv'e read every post from every forum and hadn't found an answer. Will the S10 small block conversion headers work with a block that has ANGLED Plugs?
Re: S10 conversion header question
Hedman
253.95 1982-2000 S10 with Small Block Chevy 1-1/2" Tube Diameter 2.5" Collector Diameter Shorty Design For Automatic Transmissions Only GM Style Angle Plugheads Uncoated S10 Engine Swap Street Headers Will Not Work with aftermarket cylinder heads including: Brodix, AFR, Edelbrock, Dart Jegs, Holley, World Products ADD TO CART
Jan's 53 |
Thanks so much! I’m gonna check em out right now. Anyone know of a manifold that will work?
I think you need to be clearer about what you’re asking. I’m assuming you’re talking about a sbc swap. So more info will help us steer you in the right direction.
What year of truck you have, motor and trans you’re planning on using etc,etc......
Jan's 53 |
Ha
That would probably help. 350 sbc with turbo 350 in a 1950 on a 85 s15 frame. The engine and tranny are tacked in and you can see the exhaust manifold may or may not work on the drivers side. |
Ok, so you and I are running same frame, motor and tranny. So by manifold are you talking about intake or exhaust?
I moved the motor to the passengers side about 3/4 of an inch to help clearance the steering.
Jan's 53 |
I was talking exhaust manifold. If I move the motor over, does that cause alignment problems with the tranny not being exactly centered in the frame?
Are you using those headers you posted? If so, is your steering shaft passing through the header like they do on the Patriots?
![]() Join Date: Sep 2016
You may want to look at my build thread. I have an SBC 350 swap on an S10 Frame. I used the Hedman headers and I believe the first page of the build thread has the details.
Here is the driver's side with steering. ![]()
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#13 |
Thank so for the great pic. However, I need to know if the steering column passes through the other headers. The ones linked above for angled spark plugs.
#15 |
Thanks so much!
Thread Tools | |
Display Modes | |
