02-20-2019, 01:57 PM | #1 |
1965 Rear Brake line bracket on Diff
Hi -
I need a picture of the bracket that holds the brake line T to the diff on a 65 12-bolt. An image of where the hose connect to the line on the frame would be great too. Thanks! Working on a short bed with a 12-bolt.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-21-2019, 05:48 PM | #2 |
Re: 1965 Rear Brake line bracket on Diff
So nobody has a 63-66 they could get a picture for me?
02-21-2019, 06:40 PM | #3 |
Here is an old pic that I found when I was doing the brakes. Is this the bracket you were asking about?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-22-2019, 01:07 AM | #4 |
60-66 Nut
1960-64 is going to be different than '65-'72. The pic posted by cwcarpenter98 is the '65-'72 style.
02-22-2019, 11:44 AM | #5 |
Yeah i have a 65 rear diff and am using 65 brake lines etc. It doesn't have a welded on bracket.
02-22-2019, 12:33 PM | #6 |
Moderator
My 64 used the panhard bar bracket on the rear housing for the brake line tee.
02-23-2019, 12:54 PM | #7 |
Thanks Captainfab for confirming what I thought was the case. The PO swapped in a different rear end, and just heated and bent the trac bar to make it fit. No wonder I had the bar snap on me a couple of years ago
Thread Tools | |
Display Modes | |
