Old 02-28-2019, 02:56 AM   #1
JayE72
Carb
Any recommendations on what type of Edelbrock carburetor to use on my 72 Cheyenne. 1405, 1407... Not sure which one to use? I think I had a Rochester installed. I had it rebuilt and one backfire later I'm fighting a fire. I was told to just try a new carburetor instead of having it rebuilt again, any thoughts rebuild or replace? Thanks in advance for your help.
JayE72 is offline   Reply With Quote
Old 02-28-2019, 04:28 AM   #2
toolboxchev
Re: Carb
I have a 1405 on my stocker 350. Been going strong since new 9 or so years with ethanol fuel. I have heard the new AVS series have better metering so influencing atomization or some other technical crud.
Seriously they work, either way. Bolt and go if everything else in your engine is set up properly. They do take a minor amount or adjusting but the guys on their technical site or phone are more than willing to help. I got mine dial to a tee by vac guage.
toolboxchev is offline   Reply With Quote
Old 02-28-2019, 11:20 AM   #3
HO455
Post Whore
HO455's Avatar
Re: Carb
There are any number of reasons for an engine to backfire. Carburetors are only one cause. Any carb could have a fire after a backfire. I would find the cause of the backfires before I did a carb swap. It is likely you would add to your problem instead of solving it.
Was the rebuilding of the existing carburetor done by an experienced Quadrajet professional?
RIP Bob Parks.
Old 02-28-2019, 01:09 PM   #4
rpmerf
rpmerf's Avatar
Re: Carb
Agree with HO455. Figure out what is wrong with your current setup instead of changing things and throwing parts at it.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-28-2019, 06:37 PM   #5
El Dorado Jim
Re: Carb
I run a Edelbrock 1406, it has electric choke, I have had good luck with these on other trucks as well,and they are easy to rebuild
El Dorado Jim is offline   Reply With Quote
Old 02-28-2019, 06:47 PM   #6
jocko
jocko's Avatar
Re: Carb
Was the timing changed? That would’ve been my first guess as to a backfire cause. If it was running fine (?) and absolutely nothing was done other than to remove the carb - get it rebuilt by someone - and then reinstall, I’d be on the horn to that special someone. If the rebuilder also removed and reinstalled, I’d be on the horn even quicker...
Old 02-28-2019, 08:14 PM   #7
Hugh in NC
Hugh in NC's Avatar
Re: Carb
New Edelbrock AVS Thunder 1906 650 cfm, electric choke.
Hugh in NC is offline   Reply With Quote
Old 02-28-2019, 08:50 PM   #8
68 P.O.S.
Re: Carb
I say a 1406 or a 1906. You'll also need either a fuel pressure regulator set to 5.5 psi or Edelbrock's fuel pump because they flood with more pressure than that. Also need a heat insulating gasket to stop fuel percolation.
Backfiring from the carb is a timing issue. Backfiring from the exhaust is a rich mixture issue.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-02-2019, 07:48 PM   #9
JayE72
Re: Carb
Thanks for the replies. I didn't have any timing issues that I know of. I stopped driving the truck because it was leaking fuel and the performance was no longer there. I wasn't driving crazy just driving. I parked the truck for months until I tried a guy named Randy on the rebuild. I installed it and busted it over a few times. I think I may have used a small amount of gas to get it to start.(Then the fire)
I spoke with a shade tree mechanic and he recommended that I buy a new carburetor since my old one was involved in a fire. If I decide to rebuild again can some recommend a professional? Thanks again.
Old 03-03-2019, 12:58 AM   #10
rockyrivermark
Re: Carb
I put a 1406 on my '70 350. Runs great and carb needed only small adjustments to choke and high idle
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Thread Tools
Display Modes
