03-02-2019, 09:39 PM | #1 |
Engine bay wiring question
I picked up a 72 GMC with a Chevy front conversion (I know ...). I got a box of parts since it was in pieces. I am getting close to putting her back together but I’m trying to figure out what these engine bay wires are so I can order replacements. All the engine side ends are gone so I don’t have much to go off of. I am really bad with wiring so I was hoping someone could tell me what I have and what I need. Truck is a 350 with ac. Thanks for any help
Posted via Mobile Device |
03-02-2019, 09:49 PM | #2 |
Re: Engine bay wiring question
That's the TCS wiring. You don't need it, unless you're doing a 100% stock restoration.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-02-2019, 10:05 PM | #3 |
03-03-2019, 12:20 AM | #4 |
There's really no downside. It was an early attempt at emission controls. It retarded the ignition timing under certain circumstances. I've actually never seen one with the TCS connected.
03-03-2019, 12:46 AM | #5 |
So that's what TCS wiring looks like in the cabs huh? My 71 had the wires, relay and delay mounted on the firewall, wires running to the carb and transmission. But nothing inside the cab.
Even with a 100% restore, put it into a box to say your have it I hear they're worthless, even if they happen to "work". A lot of wiring for nothing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-03-2019, 12:53 AM | #6 | |
03-03-2019, 02:32 PM | #7 | |
For what it's worth, here's my old set-up. Not able to ID one wire, it was clipped.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-03-2019 at 02:42 PM. |
03-03-2019, 03:44 PM | #8 |
My '71 has them on the firewall also. I have a red wire plugged into the IGN UNFUSED but have a wire piggybacked off on it, but the main wire in looks smaller than his picture. Do I have the right wire plugged in or do I just need to pull the tape off and follow the wires?
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 Last edited by mike1971c10; 03-03-2019 at 03:46 PM. Reason: added |
03-03-2019, 04:52 PM | #9 | |
Think I was confused. Is there a relay of some type mounted inside the cab plus the relay and delay on the firewall cab side? I found two pink wires at IGN UNFUSED.
Thread Tools | |
Display Modes | |
