03-10-2019, 12:53 PM | #1 |
LCA Bracket
I am in the process of rebuilding my front end along with installing a disc brake conversion kit. I'm cleaning things up as i go along and noticed the bracket the LCA sits in with the aligning pin is loose. It's riveted in and i think it will be secure once the u bolt is tightened? But just double checking in the event someone thinks I should grind out rivet and install new bolt and alignment head?? The other 3 are riveted in tight to the frame.
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
03-19-2019, 04:57 PM | #2 |
I'm just glad to be here!
Re: LCA Bracket
You should be OK. You don't mention the year model. If it is a pre '73, I would upgrade the u-bolts that hold the lower cross shaft to the saddles to the '73-'87 versions as they are made from a larger diameter material. All you need to do is drill out the holes where the u-bolts pass through the cross member to fit the new size bolts.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-20-2019, 01:02 PM | #3 |
Re: LCA Bracket
Thanks for the advice on the larger U bolts As soon as I'm done painting the frame in that area i'll be throwing them on. There was more dirt and grease in that area then i thought was possible Oh yeah....69 C10 step side long bed with original leaky 307 engine, three on the tree.
Thread Tools | |
Display Modes | |
