Old 03-12-2019, 02:05 AM   #1
1966 K10
1966 K10's Avatar
Power brake booster rod crossover?
Trying to piece together a PB set up and am just missing the push rod and pin. I was told later truck stuff would work but no specifics.
Anyone have the dimensions or pictures of an original rod that I might be able to duplicate? I think its just a rod with an eye on one side and threads on the other but not sure.
1966 K10 is offline   Reply With Quote
Old 03-16-2019, 04:33 PM   #2
Afirehawk1
Re: Power brake booster rod crossover?
I need this too.
Seems like the rod should be adjustable
Afirehawk1 is offline   Reply With Quote
Old 03-16-2019, 11:24 PM   #3
Afirehawk1
Where can u buy an adjustable pushrod?
Old 03-17-2019, 12:15 AM   #4
Captainfab
60-66 Nut
Speedway, Jegs and Summit all sell aftermarket universal booster pushrods and kits.
Old 03-17-2019, 01:03 AM   #5
derail
derail's Avatar
Just wanted to throw this out there because I literally just did this today. I needed an adjustable brake booster rod and went to pick-n-pull. I ended up pulling one out of a 1998 dodge ram 1500. It's way too long. I used a cutoff wheel to trim the excess close to where I needed it. Used the adjuster end to get it perfect. I put a set of harbor freight calipers on it and it's the same diameter. Done deal.
derail is offline   Reply With Quote
Old 03-17-2019, 11:34 AM   #6
60-66
60-66's Avatar
Heres a complete kit. Pictures show the rod
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-17-2019, 12:48 PM   #7
1966 K10
1966 K10's Avatar
Thanks so much! Happen to have the overall measurement by any chance?
Old 03-20-2019, 04:54 PM   #8
60-66
60-66's Avatar
Total length of the rod is, 8 5/8
Thread Tools
Display Modes
