Old 03-16-2019, 03:35 AM   #1
jmrobertson30
70 C20 4x4 front brake drums
HI,
I'm looking for some brake drums for my 70 4x4. They are 8 lug drums and I can't find them anywhere. I was told if I found a 71 and got everything from the knuckles out, I could convert front end to disc brakes. Any suggestions or recommendations would be greatly appreciated.
Jeff
jmrobertson30 is offline   Reply With Quote
Old 03-16-2019, 01:08 PM   #2
B. W.
B. W.'s Avatar
Re: 70 C20 4x4 front brake drums
I don't believe front drums are available. I converted my '70 K20 to disc but I used a complete donor axle from a '71. I believe you just need the parts from the knuckle out but am not sure.
It may be just as cheap to buy a complete disc D44. GM put them under square bodies until the mid '70's. The bonus with the later 44's is you get the larger axle u-joints.
B. W. is offline   Reply With Quote
Old 03-16-2019, 02:12 PM   #3
HO455
Post Whore
HO455's Avatar
And a better turning radius.
RIP Bob Parks.
Old 03-16-2019, 03:35 PM   #4
kwmech
1971 to 1976 will work
kwmech is online now   Reply With Quote
Old 03-16-2019, 09:56 PM   #5
jmrobertson30
Did you just find your donor axle from a junk yard? And what is a complete disc D44?
Thank you all for your suggestions and help.
Old 03-16-2019, 11:27 PM   #6
B. W.
B. W.'s Avatar
I used the axle from a 71 gmc K25. I have the whole truck, I've just about stripped all of the good parts off of it. (bought 2 worn out trucks to make one worn out truck!)
What I meant by a complete disc D44 is just the whole axle. I've seen them for sale pretty cheap ($100) but it depends on condition, etc.
Old 03-17-2019, 09:45 AM   #7
HO455
Post Whore
HO455's Avatar
Originally Posted by jmrobertson30 View Post
Did you just find your donor axle from a junk yard? And what is a complete disc D44?.
D=Dana. The manufacturer. 44 is the model.
https://en.m.wikipedia.org/wiki/Dana_44
You would be looking for an open knuckle disc brake version. From a 1971 to 1975 Chevy/ GMC truck, Blazer or Suburban.
RIP Bob Parks.
Old 03-20-2019, 10:37 PM   #8
El Dorado Jim
HI,
Jeff
yes, you can just change from the knuckles out, I did this on a 70 gmc Jimmy i had, but i also had to use the axles too, I had a complete front housing at the time so I had all the parts, I didnt just change complete housings, because they were different axle ratios...
El Dorado Jim is offline   Reply With Quote
Old 03-23-2019, 08:27 AM   #9
Furno68C20
I Just converted my 68 c20 to front disc. I have the old drums and knuckles 8 lug.
Furno68C20 is offline   Reply With Quote
Old 03-23-2019, 11:23 AM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have a 72 Dana 44 HD that I'm getting ready to put ont the parts board.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-23-2019, 09:39 PM   #11
Hotcorner
Hotcorner's Avatar
What? The drums are unavailable for a D44?
Hotcorner is offline   Reply With Quote
Old 03-24-2019, 11:35 AM   #12
B. W.
B. W.'s Avatar
'70 was a "one year only" open knuckle, drum brake. Guess the drums are different from '69 back? Just looked on Rock Auto, no front drums listed for a 70. Front drums listed for a 69 but out of stock.
Old 03-24-2019, 04:12 PM   #13
palallin
Before this conclusion becomes Internet Truth, does anyone have '69 drums and '70 drums to compare? Rock Auto's listings are not infallible.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-24-2019, 07:17 PM   #14
B. W.
B. W.'s Avatar
That would be good to know. The 69 & 70's do share the same brake shoes & wheel cylinders (CQ shows 69 has a standard & HD wheel cylinder, 70 only lists a HD)
I would think the only difference in the drums (if there is a difference) would be the center bore. Or, maybe the mounting surface is a different height?
Thread Tools
Display Modes
