03-16-2019, 09:37 AM | #1 |
Trac Bar or panhard bar for Rear drop
Im here again looking for suggestion. I have a 5 in rear coil drop. I'm going to replace the original panhard bar due to reading that I need to recenter the rear end. What would you'll suggest an adjustable 24" panhard bar or go with the long trac bar(one that bolts to the frame rail). Not sure if important but the truck has a LS 6.0. Engine. Appreciate any suggestions
03-16-2019, 09:48 AM | #2 |
Re: Trac Bar or panhard bar for Rear drop
There's a ton of options out there depending on what your budget is and what your long term goals are suspension wise. If you're not looking convert over to coilovers and keep what you have or are on a budget.
http://nolimit.net/products#!/~/prod...32&id=26244500 200 bux done deal. Or, full conversion: http://nolimit.net/products#!/Fatbar...tegory=6157532 https://www.jegs.com/i/QA1/122/R110-...RoC3dYQAvD_BwE https://www.ridetech.com/application...airbar-system/ |
03-16-2019, 12:22 PM | #3 |
Track bar -- Panhard bar....... One and the same...
03-16-2019, 12:48 PM | #4 |
Post Whore
Both of the options you listed will work but longer is better as it will result in less side to side movement of the axle as the suspension travels. Do a search of the suspension thread for a more detailed explanation.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-16-2019, 03:01 PM | #5 |
One other thing that may or may not apply to you. A panhard bar in the stock location might not clear an aftermarket diff cover if it is deeper. I bought an adjustable one that fit on the stock diff bolt, would not clear the cover. I ended up getting one from CPP that bolts to the U-bolts and the stock frame mount on the opposite side frame. Like HO455 said longer bar is better.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
03-18-2019, 06:17 PM | #6 |
Appreciate the info. Thanks for replying
03-18-2019, 06:56 PM | #7 |
for a five inch drop youll definatly want to go with a longer trac bar. I ordered mine from ECE. very nice and 2 different mount locations
1967custom |
03-19-2019, 06:51 AM | #8 |
I second the long ece bar.
Could be just me, but the rear end felt more stable after the install too.
John 69 c20, 396, th400, dana60, ps, ac |
Thread Tools | |
Display Modes | |
