Old 03-16-2019, 12:00 PM   #1
JerryIndy2112
JerryIndy2112's Avatar
Brake issues
My front brakes were locking. So I pulled it into garage. Pulled wheels and took it all apart. Rotors were too thin to turn. So I ordered new rotors, calipers and bearings. All came and I began rebuilding. Rotors fine. Bearings fine. Put on calipers. And hooked up brake lines. Passenger side hooked up. Drivers side had wrong brake line connection. Took caliper back to O'Reilly and they had no answer. They say they could re order, but 50/50 chance it would be wrong. They are all same part number. Putting pictures up to show what I have.
The first is connection I have, the second is drivers side as sent.
Can i change brake hose? Do i order a new caliper?
JerryIndy2112 is offline   Reply With Quote
Old 03-16-2019, 12:14 PM   #2
rockyrivermark
Re: Brake issues
I have a '70 c10 with 71' disc brakes 6-5 lug conversion to front disc.
I went through and changed everything out last year.
Stainless lines. Rotors etc.
my passenger side has an adaptor fitting on it.
I had to reuse that.
I'm not sure what size that fitting is but needs to be flared adaptor.
Hope this helps.
Mark
Try this link. Just search it. Not sure if it's what you need
https://www.cjponyparts.com/classic-...-1987/p/45045/
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-16-2019, 03:43 PM   #3
JerryIndy2112
Re: Brake issues
This is what I got to solve the issue.
https://www.bobschevytrucks.com/1971...hose-left.html
I am a bit upset that my left and right will have different hoses. I will have to change again sometime in the future. But this will get my truck back on the road. I can continue to work on other issues for now.
Jerry
Old 03-16-2019, 03:53 PM   #4
HYPR
HYPR's Avatar
Re: Brake issues
Jerry
That hose looks very similar to what I got from NAPA for my '72 C20 CS BB.
The hose was about .125" shorter than the original so at full droop the hoses are really tight. Not a big deal since I will not be off roading the truck and will never see full droop unless it is on a lift or jacked up. I also plan on lowering it and if the drop spindles don't lower it enough I will be taking about one coil length from the springs which will reduce the travel about .5".
Just be sure the bleed nipple is on the top of the caliper.
HYPR is offline   Reply With Quote
Old 03-16-2019, 04:14 PM   #5
HO455
Post Whore
HO455's Avatar
Re: Brake issues
I am assuming you mean the is hose 1- 1/4" shorter? And welcome aboard.
RIP Bob Parks.
Old 03-16-2019, 06:27 PM   #6
HYPR
HYPR's Avatar
Re: Brake issues
Thank you for the welcome.
Nope, the front hoses are about 1/8" shorter then the original front hoses.
I replaced all three flex lines because they were rotted from the inside causing not enough brake pressure. The PO who sold it to my buddy had replaced the MC and Booster thinking that was the problem.
Oh and BTW, the rear hose all that NAPA offered was either the 18.125" or the 21.125" but not the 13.875" that came with the truck so I will simply install a line clamp to the underside of the bed to take up the slack.
I also removed the bleeders and two were rusted inside so they would not bleed correctly so I replaced them with Russel Speed Bleeders.
Bob
Thread Tools
Display Modes
