Old 03-26-2019, 11:34 PM   #1
thehata1
Noisy DBW Throttle Body
I'm trying to wrap up my swap and started it for the first time last weekend. I noticed that when I turn my key into the run position, my DBW throttle body powers up or engages loudly. The engine, tac and peddle came from the same truck. I drove that truck for 6 months and never really heard it before.
Any thoughts?
thehata1 is offline   Reply With Quote
Old 03-27-2019, 04:05 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Noisy DBW Throttle Body
It's normal for them to make some noise when you first turn them on. How loud is it?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-27-2019, 06:45 AM   #3
homemade87
If you have the air intake off you can here it pretty good . This is normal . It does a little quick test open and close to check to see if there is a problem with the tb binding . If it detects a slight resistance it will throw a code and will not open the tb after starting the engine .
This is GM fail safe test so you dont have a stuck open tb and a run away engine .
homemade87 is offline   Reply With Quote
Old 03-27-2019, 10:51 PM   #4
thehata1
You can here it at the very beginning of the video posted to my ig account: https://www.instagram.com/the_not_asian_caucasian/
To me it's as loud as a starter engagement. But, you can put your hand on the tb and it's definitely it.
Old 03-27-2019, 10:52 PM   #5
thehata1
The factory air intake is on it. And, after crank up, you can rev the motor. I posted a link to a video with the sound just before this post.
Old 03-28-2019, 12:34 AM   #6
Wildkarde
Thats perfectly normal. Its a sound you really get used to when tuning them, as evey time you load a new calibration it cycles the computer.
Wildkarde is offline   Reply With Quote
Old 03-28-2019, 06:05 AM   #7
Wgesnerjr
Wgesnerjr's Avatar
yes, normal sound out of mine. running that way for almost a year, no problems.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 03-28-2019, 12:02 PM   #8
thehata1
Thanks guys. I just never noticed it in the other truck.
Thread Tools
Display Modes
