Old 03-28-2019, 09:11 AM   #1
sim
1970 c20 disc brake swap
hello,
been trying to figure out if this can work.
1977 disc brake spindle from a g30, I replaced the "big disc" with a normal one
had to change upper and lower ball joint
longer hydraulic hose
everything works to this point. spindle is mounted and moves freely.
the point where I am a little bit curious is the steering. my 70 c20 got 5/8" tie rods (if i´m right?)
the van spindle asks for a 11/16" tie rod.
Is there any other solution than buying this super expensive hotchkis tie rod adapter sleeves where you can connect a 11/16 tie rod to a 5/8.
remember that I´m from Europe. So shipping heavy and big parts like a spindle is very expensive.
sim is offline   Reply With Quote
Old 04-01-2019, 03:43 PM   #2
SCOTI
SCOTI's Avatar
Re: 1970 c20 disc brake swap
Would these work for you?
https://www.performanceonline.com/19...ONVERSIONS-Pr/
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-01-2019, 06:03 PM   #3
SimonTek
Really what are the odds that we would both be in the process of doing the same thing on a c20. I pulled up the forum, because I couldn't remember how the steering went.
1969 Chevrolet C20 Longbed
I-6 250, SM465
SimonTek is offline   Reply With Quote
Old 04-04-2019, 08:19 AM   #4
77c10bowtie
77c10bowtie's Avatar
have a machine shop open the taper in the drag link to run tie rods off the 77
77 SWB 2wd. gutted, caged, slicks, not weighed yet
02 Duramax CCSB 4x4 12.7@104 6750lbs
77c10bowtie is offline   Reply With Quote
Old 04-06-2019, 04:22 AM   #5
sim
@simon tek
Haha, even the same name!
Thank you all. I've ordered the hotchkis tie rod adapters.
I'll let you know if it works.
Thread Tools
Display Modes
