Old 03-30-2019, 04:10 PM   #1
flykelley
Dakota Dash VHX-67C-PU Tach issue
Hi Guys
Did a 5.3/460LE swap from a 2000 Chevy pickup to my 69 C-10. The tach on the Dakota reads 2x higher that the tach when I hooked up a scanner to it. It also doesn't appear to be shifting into overdrive. Running about 3000RPM at 60 MPH. I have adjusted the shifter rod. Moved the shirt lever real slow from netural to what I think is overdrive still running high RPM according to the dash Tach. At idling, the scanner shows 678RPM while the dash tach shows about 1250RPM. Has anyone seen this issue? Trying to figure out which one is correct.
Thanks Mike
flykelley is offline   Reply With Quote
Old 04-01-2019, 11:47 AM   #2
dayj1
Re: Dakota Dash VHX-67C-PU Tach issue
Originally Posted by flykelley View Post
Hi Guys
Thanks Mike
Can you change the input type on your DD tach? If so, set it to 4 cylinder. By default, thats the signal frequency you will get from a Gen III PCM.
dayj1 is offline   Reply With Quote
Old 04-01-2019, 11:59 AM   #3
flykelley
Yes I can change that, will give it a try.
Old 04-01-2019, 01:00 PM   #4
Nodnarb76
Nodnarb76's Avatar
I ran into this when hooking up my DD VHX dash.
Set it to 4 cyl mode and now works fine.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-02-2019, 01:58 PM   #5
flykelley
Hi Guys
Well my stuff is ass backwards. Got into the setup menu and it was set for 4 cylinders. I played with different settings and the 8 cylinder pretty much matches what the scanner is displaying for RPM. Don't understand it but it appears to be working ok. Showing around 2300 RPM at 70 MPH.
Mike
Thread Tools
Display Modes
