03-31-2019, 09:15 PM | #1 |
Tire Pressure
70 3/4 ton with 265/75/16 tires. What tire pressures are you all running empty?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
03-31-2019, 09:51 PM | #2 |
Re: Tire Pressure
235/85/16 tires running 35 psi.
1972 GMC K2500 Super Custom Matt |
03-31-2019, 11:24 PM | #3 |
20' Daredevil (Ret)
Re: Tire Pressure
'72 K20 with 255/85-16s, Load Range D (8PR) running 35 psi.
04-01-2019, 07:30 AM | #4 |
Re: Tire Pressure
235/85R16 on my 70 C20, I run somewhere between 36 and 40.
245/75R16 on my 97 burb, I think I run the factory spec - 36psi
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-01-2019, 11:37 AM | #5 |
Re: Tire Pressure
Thanks for the replies. I'm going to lower the tire pressure some and see if I can keep the rubber on the pavement. Thanks
04-01-2019, 05:16 PM | #6 |
Re: Tire Pressure
What does "keep the rubber on the pavement" mean? Isn't the rubber of the tires aways on the pavement? Do you have a max pressure in small raised letters on your tire?
04-01-2019, 06:26 PM | #7 |
Re: Tire Pressure
I have 235/85/R16 tires on a '68 C/10. Yokohama Geolanders. They take 45 PSI.
04-01-2019, 07:32 PM | #8 | |
Re: Tire Pressure
I know part of it is the leaf suspension at the rear, it seems sometimes when I hit a really rough patch of road in a turn, seems like the rear bounces off the road. Not a good feeling. Usually when I am going just a little too fast and and not expecting it. There is so much construction around here on the freeways these days. I've actually seen the wheels leave the pavement on a unloaded set of doubles, usually bottom dumps.
Thread Tools | |
Display Modes | |
