Old 04-18-2019, 10:10 AM   #1
bb400ho
Active Member
1968 lower trim fit issue
Hello, i have a 68 gmc short fleet that im working on. i purchased a repo bed from a member and the whole set of side trim. most of it looks like it will fit great. the rear wheel well arches are the exception. it looks like the top of the trim will end up about a 1/4 inch below the body line in the rear. i wondering if anyone knows if its the bed or the trim?
thanks Bryan
bb400ho is offline   Reply With Quote
Old 04-18-2019, 01:25 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: 1968 lower trim fit issue
Got Pics?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 04-18-2019, 06:25 PM   #3
sick472
sick472's Avatar
My reputable aftermarket trim did something like what you are taking about on my original bed with aftermarket wheel-well patches. I actually found that if I started with the wheel well trim and balanced the distances below the body line by rotating the trim until it was the same distance below the body line front and back that it looked very good. Them I positioned the straight pieces to have the same gap along the rest of the length. I do not think that the trim is supposed to be right on the body line. I could be wrong, but that's what I had to do to keep one side (front or back) from being grossly different from the other. I was also putting in all new holes and not trying to reuse any of the old ones.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-18-2019, 10:01 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
That is correct. The trim sat down from the body line about a 1/4” of in inch. I bought an aftermarket bedside for my old ‘68, and when fitting it, I noticed that. I was immediately PO’d, but after going over and looking at the original bedside, it was the same way.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-19-2019, 12:51 PM   #5
bb400ho
Active Member
thanks for the replies ill try to get pics later. i hope its close enough to line up with the cab and ft fenders. otherwise ill probably have to try to lower them a little
thanks Bryan
Thread Tools
Display Modes
