Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 04-21-2019, 12:31 PM   #1
cucvzuz
Sending parts in for Zinc Plating.
I am sending some parts in to be zinc plated. I only have a few parts and the company will do just one part but tgey charge a $150 minimum. I have had a few things done in the past and it takes alot to go over the minimum.
If you have anything you would like plated post what you have.
To help cover the cost I'm asking $10 for a small flat rate box and $20 for a larger flat rate box. You can ship me the parts with a return label and as soon as they are done ill send them back to you. Turn around is usually about a week.
Id like to send in parts in 2-3 weeks.
Frank
cucvzuz is offline   Reply With Quote
Old 04-22-2019, 03:23 PM   #2
1rippen6
Re: Sending parts in for Zinc Plating.
If I'm understanding correctly whatever I can fit into a large flat rate gets coated for 20?
1rippen6 is offline   Reply With Quote
Old 04-22-2019, 04:54 PM   #3
cucvzuz
Correct, Within reason.....Not like 300 bolts.
Old 04-22-2019, 05:12 PM   #4
1rippen6
Ok, I get a group together and take a picture so we are on the same page.
Old 04-22-2019, 07:17 PM   #5
richard2717
Equal opportunity joke ofender
richard2717's Avatar
would something like this have to be disassembled for plating or can it be done as shown? What prep work is required before sending?
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 04-22-2019, 09:05 PM   #6
cucvzuz
Funny you asked. I'm sending in the same latches. I was going to send them in whole and see how it goes. My plan is to strip the paint then remove the original zinc with muratic acid.
Old 04-23-2019, 03:50 PM   #7
richard2717
I am not going to be ready for a while but I would like to know what you find out and how they turned out if able to be done in one pc.
Richard
Members I have met.
Old 04-23-2019, 05:22 PM   #8
cucvzuz
I'll post some pics when they get back.
Old 04-23-2019, 05:43 PM   #9
1rippen6
I was running behind today, I'll try to get some together tomorrow.
Old 04-23-2019, 05:55 PM   #10
richard2717
Would bead blasting in the cabinet be acceptable for cleanup or would that make the too ruff still? I have zero experience with this.
Members I have met.
Old 04-23-2019, 07:00 PM   #11
Terrysch
Richard,
You want to do both.
First soak them in muriatic acid,
Then blast them. Be thorough in the center area with the spring.
Then they will be ready for zinc coating.
Surface preparation is actually the most critical part for any coating.'
Whether it is zinc coating in this case, or painting.
The reason for both is to remove the remnants of the old zinc coating and the rust.
Did this for my same side latches and they turned out great. They also now work like new.
I am a retired mechanical engineer who worked for John Deere, Mercury Marine and two boat companies - Tracker Boats and Four Winns. Been around painting, coatings for a very long time. Including working with some great painting and coating engineers, They get the credit for what I have learned. But I usually claim to know little. Humility.
Terry
Terrysch is offline   Reply With Quote
Old 04-24-2019, 05:56 AM   #12
Harold Holbrook
Can I get in on the zinc plating?
Harold Holbrook is offline   Reply With Quote
Old 04-24-2019, 11:53 AM   #13
1rippen6
Here is what I was thinking, I should be able to clean everything over the weekend. I may add a few more smaller items if I can find them.
Old 04-24-2019, 12:11 PM   #14
Terrysch
Dwayne,
I think these are great parts for the zinc plater.
Thanks for posting the picture of the parts.
Seeing your picture reminded me to add the hatch "lift struts" to my list for zinc plating.
But not ready to do all of my parts yet.
Terry
Old 04-29-2019, 12:35 AM   #15
Harold Holbrook
Terry, Are you still looking for more parts, I have some that need zinc plating. Send me the cost.
Old 04-29-2019, 01:58 AM   #16
Terrysch
Harold,
cucvzuz is the one coordinating sending in parts for zinc plating.
I am not ready to do my parts yet.
Terry
Old 04-29-2019, 07:51 AM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hatch latches turn out nice. Here are some examples of clear zinc...the wiper fluid spray nozzles look amazing
Old 04-29-2019, 08:38 AM   #18
Terrysch
DeadheadNM,,
They look great.
Did the plater cucvzuz plans to use do these parts for you?
On the bolts, are you concerned with them threading with the added plating thickness? When are you going to try installing them?
Thanks for the posting and pictures!!!
Terry
Old 04-29-2019, 08:42 AM   #19
Terrysch
What are the other parts in pic 2 besides the wiper nozzles?
The parts in the center in the center in pic 3?
I am having a brain fart remembering those parts. LOL
Old 04-30-2019, 07:40 AM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I used Kehr coating in Albuquerque. Not the easiest to deal with but were local at the time. The recoat doesn’t interfere at all with threading bolts. In fact nearly all my bolts for the blazer build were replated - some were nos and a few new.
I don’t have nozzles shown - I have a pic somewhere though. The second pic shows replated fuel tank straps bolts and the related plates.
Third pic middle row shows powder coated bezel things that secure the hatch hinge gaskets to the top as well as hinge to hatch for single wall tops.
Old 07-18-2019, 08:34 AM   #21
70STOVEBOLT
70STOVEBOLT's Avatar
Bringing this to the top, would like to see pics of finished products.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-19-2019, 04:20 PM   #22
6t727t2
Active Member
me to
6t727t2 is offline   Reply With Quote
Old 07-19-2019, 04:40 PM   #23
70STOVEBOLT
Also, if it's not too late to get in the game, I would send some parts also.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Thread Tools
Display Modes
