05-09-2019, 11:49 PM | #1 |
Front U-Bolt Question?
The Rear Alignment Dowel On The Front Crossmember Where The Front Control Arm Fits Into To Secure It Looks Like It Was Ground Down Or Flattened Out. I Replaced It With An Allen Head Bolt but Cant Get It Secured In The Hole The Same Time As The Front..
Is One Dowel Enough To Keep Stuff From Sliding.. Also Do i Need a Bolt In The Center Hole If I Grind The Head Down Flat Or The U bolts Okay? Thanks Posted via Mobile Device |
05-10-2019, 01:04 AM | #2 |
Post Whore
Re: Front U-Bolt Question?
I'm not sure about all questions you have. But the only index rivet on the lower control arm shaft is under the front U-bolt. The back saddle rivet doesn't index into the shaft. If you post some pictures maybe we can help more.
I had the shaved rivet problem on my Burban's front saddles so I replaced them with Allen head bolt too. I did have to grind them down shorter so the shafts would seat properly in the saddle. But that may have been due to the modifications I did to the shafts. Here is a link to my WMB thread post 244 that may help you. http://67-72chevytrucks.com/vboard/s...698377&page=10
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-10-2019, 09:59 AM | #3 |
If The Front Rivet Is Only Used Is Used For Indexing That Answers My Question.. Thank You So Much..
05-10-2019, 11:12 AM | #4 |
That is correct. I replaced my rivets with the allen head bolt as well. While you're in there, upgrade the the u-bolts to the 9/16". They're Dorman 13503 . The stock 7/16" and the 1/2" u-bolts tend to snap when you crank the wheel all the way and back up.
72 C10 lwb fleetside -stock 350/350 combo |
05-10-2019, 01:42 PM | #5 |
The GM replacements are also 9/16".
05-10-2019, 02:19 PM | #6 |
I just posted about this, did you have to "dimple" the crossmember to get the 9/16" u-bolts on a 67-72?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
05-10-2019, 04:50 PM | #7 |
Post Whore
What do you mean to "dimple" the cross member? I had to drill the holes in the saddle's and crossmember on my 67 to be able install 9/16" U-bolts, but I don't remember having to dimple anything.
05-11-2019, 01:08 PM | #8 |
Same here, just ran a 9/16" bit through the hole and that was it. No dimpling of anything involved.
Thread Tools | |
Display Modes | |
