Old 05-11-2019, 01:34 PM   #1
chewychevy67
Water pump spacer and belts question
I addad a roller cam to my 327 and the water pump needed a 1/8" spacer to clear the timing cover. So now my water pump pulley is 1/8" out and I can't rectify that as my pulley is as far back to the pump as it can get. If I leave this will i just have belt problems.?
chewychevy67 is offline   Reply With Quote
Old 05-11-2019, 04:11 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Water pump spacer and belts question
Crank pulley spacer .
https://www.summitracing.com/parts/qti-rm-715/overview/
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-11-2019, 04:14 PM   #3
chewychevy67
But the pulley needs to go back and I though about pressing the bub back 1/8 but the pulley already just clears
Old 05-11-2019, 04:28 PM   #4
Grumpy old man
You spaced the water pump pulley out 1/8 ? Space the crank pulley out 1/8 .
Old 05-11-2019, 08:33 PM   #5
chewychevy67
Yes I get that but the air cond, alternator and power steering are not going to be in line. I just don't want to be throwing belts over it.
Thread Tools
Display Modes
