Old 05-17-2019, 04:43 PM   #1
macdodd127
spark plugs
I need to replace short spark plugs in a 350 with headers,,,any suggestions? I'm using accel right now,,,to damn expensive to keep replacing with them.
macdodd127 is offline   Reply With Quote
Old 05-17-2019, 05:42 PM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: spark plugs
I heard that AC Delco R43TS are a cheap equivalent. Check it out and let us know.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 05-18-2019, 03:44 AM   #3
mr48chev
mr48chev's Avatar
Re: spark plugs
I'm not sure what Accel cost now but remember pulling the set of plugs I replaced a se of Accels with back out and putting the Accels back in when it wouldn't run worth squat with the new plugs.
In this case we really need the plug number of the plugs you are running now as Accel makes shorty header plugs for the older heads that take the plugs with the washer and the taper seat plugs.
NGK shows a shorty taper seat plug NGK UR6 6630 but no info on the heat range from my source. .
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 05-25-2019, 06:30 PM   #4
macdodd127
Re: spark plugs
Ok,,got a set of accel 576S/8199 spark plugs. I've got a stock 350 sb with headers on it. What should the plugs be set at? Out of the box, they're set at .030 which I know is, I think, to close. Any advise? Thanks,,,,Bill
Old 05-27-2019, 12:02 AM   #5
mr48chev
mr48chev's Avatar
Re: spark plugs
It calls for .035 if you run points. Probably .045 with hei Some will say more with HEI but the strap will only spread so far.
Beyond that you are going to get into individual tuner's theories on it.
Thread Tools
Display Modes
