Old 05-20-2019, 02:08 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Solution for 1 speed wiper switch
Since it seems that I was unable to find anyone making a 1 speed wiper switch (2 speeds ones are available) I was able to "make" one that works just like the original.
Buy a 1 speed wiper switch for a '65 Chevy Chevelle. When you compare it to an original one, they are identical other than for the longer shaft.
I took measurements from my original switch and used a Dremel cutoff wheel to trim it down. Then I took the wheel and after marking, I cut a groove to replicate the original one, to hold the knob.
It mounts just like the stock one and has the same wire connection. Works great!
Hope this helps someone.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-20-2019, 03:41 PM   #2
350TacoZilla
Re: Solution for 1 speed wiper switch
Good to see this type of info. You never know when someone will be alongside the rd with no lights and need this tip.
350TacoZilla is offline   Reply With Quote
Old 05-20-2019, 10:22 PM   #3
slepysal
slepysal's Avatar
Improvise !! Great job !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-21-2019, 10:39 AM   #4
nxtruck
nxtruck's Avatar
Thanks for sharing this!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 05-21-2019, 01:58 PM   #5
61K10
61K10's Avatar
does the set screw fit in the groove?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-21-2019, 06:45 PM   #6
chevy_mike
chevy_mike's Avatar
What set screw? My factory wiper knob had little spring clips inside that grab the groove.
Old 05-22-2019, 02:25 PM   #7
61K10
61K10's Avatar
My 61 has a set screw on the knob. Maybe changed when they changed the knob style?
1961 chevy K10
Thread Tools
Display Modes
