6.2 4l65e won’t shift
Hey guys I have a question I have a 58 with a 6.2 and a 4l65e running factory fuel injection and a connect and cruise transmission trans part#19260380. Problem is range switch a b c and p all read hi and the trans commands 3rd gear at all times and will not shift. I have disconnected the connector at the trans and it has 12v ont the pink wire and ground on the black wire I can short out the black wire to each range a b c p and they read low. Trans still no shift. Does the range switch have anything to do with the no shift. Or am I fighting different issues? Any help or ideals would be greatly appreciated.
![]() Join Date: Apr 2018
Re: 6.2 4l65e won’t shift
I believe there is a red/white wire that is 12 volt positive all the time and then the pink wire is hot with ecm on. I had issues with mine being stuck in limp mode and it was improper voltage on the red/white wire. Just something to look at
Thanks for the response I did load test the powers and grounds to the Tcm and the transmission. They where good. I talked to gm performance and found out the the connect and cruise transmission is based on a 2006 gto transmission I wired my truck based on a Silverado or Tahoe so I got a pin out for a gto and going to try that route.
Thread Tools | |
Display Modes | |
