06-28-2019, 10:45 AM | #1 |
Need help finding a Crank/Run Wire for 5.3 swap - 87 Silverado
I'm working on the wiring for my LS swap -wiring is not my strong suit. I have a premade harness which really helps, but I need to find a wire to connect the harness to that works in Run/Start. I tried reading a wiring diagram, but I'm lost.
I'm sure this is pretty straightforward for most - this is a 87 TBI Truck. I still have the original wire harness in place, its just all disconnected on the engine side (since the engine is gone). Is there a wire i can cut and splice into for Run/Start? |
06-28-2019, 12:14 PM | #2 |
Post Whore
Re: Need help finding a Crank/Run Wire for 5.3 swap - 87 Silverado
i assume your talking about your switch on power...i used the switch on power wire that went to the hei on mine
06-28-2019, 12:18 PM | #3 |
I believe that is the one - power to the LS wire harness fuse block.
There are a few HEI wires - any idea which one I'm looking to splice into? |
06-28-2019, 12:57 PM | #4 |
The main one is pretty good size, usually tan in color if I remember correctly.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-28-2019, 04:18 PM | #5 |
Post Whore
yep..its the biggest wire in that plug...i think tan is correct..but its been awhile since i did mine
Thread Tools | |
Display Modes | |
