Old 06-28-2019, 07:05 PM   #1
yote1234
yote1234's Avatar
250cu. in. with powerglide... which flex plate?
i am replacing my worn out 292... 3-on tree. with a brand new 250cu.in. crate engine and a fresh powerglide from a 65-66 c10. my question is which flex plate? and converter do i use?
any help ? thx dave
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 06-28-2019, 07:48 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 250cu. in. with powerglide... which flex plate?
https://www.rockauto.com/en/catalog/...,flywheel,5348
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-29-2019, 02:24 PM   #3
yote1234
yote1234's Avatar
i thank you for your responce, my question is ? is the 230 flexplate the same as 250 flexplate?
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 06-29-2019, 03:39 PM   #4
Wrenchbender Ret
The 230 & 250 use the same flexplate. Use a converter for the power glide & a flex plate to match. The small block v-8s used the same flex plate were it bolts to the engine but I'm not sure if the bolt pattern to the converter will fit.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-29-2019, 04:55 PM   #5
Clyde65
Clyde65's Avatar
Same block 230/350
Clyde65
Rebuild of Clyde
support our troops!
Old 06-29-2019, 07:23 PM   #6
vince1
I think he's looking for a flex plate, not a flywheel.
vince1 is offline   Reply With Quote
Old 06-29-2019, 08:02 PM   #7
yote1234
yote1234's Avatar
George
awesome . thx dave
Originally Posted by Clyde65 View Post
Same block 230/350
i thank you, dave
yes ... flex plate... thx dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 06-29-2019, 11:36 PM   #8
Captainfab
60-66 Nut
There are 2 diameters of flexplates for the I6 and V8's. The 153 tooth 12-3/4" and the 168 tooth 14". You will need the correct starter for the diameter of flexplate that you choose.
Old 06-30-2019, 11:47 AM   #9
rvrfoot
Some starters will do both flex plates.
rvrfoot is offline   Reply With Quote
Old 06-30-2019, 12:32 PM   #10
yote1234
yote1234's Avatar
thx captain....
thank you.
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Thread Tools
Display Modes
