Old 12-01-2003, 12:26 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Can someone measure a t-case please
Jose came by a few days ago to pick up a t-case. Only problem was the darn thing wasn't drilled out for the big bolts on the side mount. Anyone know why? anyway, I decided to use the case myself and I am drilling and tapping the holes, but I need to know how deep I can make them without blowing into the case.
Could someone measure the depth of the two side mount holes on a 205 t-case for a 72 k 20. Your will have to have a 205 laying around to do this.
I also need to know the size of the bolt. I think it is a 9/16 bolt.
Thanks in advance
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-01-2003, 12:45 AM   #2
jose
jose's Avatar
I am still stumped as to why those holes aren't there . I bet you that is the reason the bell housing is cracked on both sides . Maybe some one here knows what it came out of originally ?
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 12-01-2003, 12:50 AM   #3
Scrub
Scrub's Avatar
Did you figure out who was trying to break into your house?
Scrub
Old 12-01-2003, 12:57 AM   #4
jose
jose's Avatar
Neighbors gave me a general discription of the guy and i am keeping an eye out for him thru my scope .
68 GMC 4x4 SWB
jose6772@yahoo.com
Old 12-01-2003, 02:33 AM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The only time I've seen those holes used is on a divorced case set up...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-01-2003, 10:32 AM   #6
Scrub
Scrub's Avatar
Hmm..
The frame on my project truck has brackets that are rubber mounted and would go into these holes. My parts truck also had the brackets, but the tcase was not drilled. I started looking at pictures on the web and found a case out of a t400 that wasn't drilled either. I want to drill mine as shown in this pic, Which is also a t-400 case.
I don't get it. If you don't use those holes, what keep the tcase from rotating?
Edit: crap, the pic didn't take
Scrub
Old 12-01-2003, 10:34 AM   #7
Scrub
Scrub's Avatar
Try this pic again
Scrub
Old 12-01-2003, 11:06 AM   #8
714x4
Scrub, I just removed my transfer case this weekend. I'll measure the depth of those holes for you this afternoon when I get home from work.
714x4 is offline   Reply With Quote
Old 12-01-2003, 09:50 PM   #9
JimKshortstep4x4
Talking
Using a 3/8" diameter pin in lieu of a depth gauge, I came up with a hole depth of 1 5/8" in the transfer case that I have, (71 NP 205)
Incidently, all of our 4x4's with the NP 205 have the side brace
mounting. It is my understanding that some of the later trucks (73 and up) eliminated the side brace.
Jim
Old 12-01-2003, 10:15 PM   #10
cheyenne10
cheyenne10's Avatar
drilling for mount
Board member Pont drilled an undrilled case last year. Try to get him to tell you how he set it up.
Bob
cheyenne10 is offline   Reply With Quote
Old 12-01-2003, 10:25 PM   #11
Scrub
Scrub's Avatar
Thanks for the information. I kinda figured it was a year based change. The older trucks were just built stronger.
Time to go play dentist.
Scrub
Old 12-02-2003, 12:49 AM   #12
Pont
I need another Barley Pop
Pont's Avatar
Hey Bob, you've got a good memory!
Scrub, when the Rockwell t-case went bad in my truck, I decided to put later model stuff in my truck, easier to get parts.
The 4 spd trans and 205 t-case I installed came out of a 78 Blazer and the t-case was NOT drilled for the torque mount coming off the passenger frame rail. Off hand, I don't recall the correct bolt size but I think 9/16" sounds right to me. As for drilling depth, I drilled mine 1 1/2" deep (which is not deep enough) and used a flat washer and lock washer at the bolt head to take up the gap and firmly secure that bracket to the side of the t-case. Back when I did mine, someone on the board gave me a drill depth of 1 5/8" (I think) but I didn't want to take the chance of busting through the case. I'm sure there is plenty wall there on the case but I just felt better not drilling as far and taking up the slack with washers. A better alternative would be to drill it 1 1/2" deep and just run a 1/2" shorter bolt. Overall, mine truned out really good. No complaints at all. If you don't run the torque mount at all, I'm sure it will work but you might end up with a broken trans to t-case adapter like so many other people have. Drilling and taping is cheap insurance in my opinion.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 12-02-2003, 01:10 AM   #13
Scrub
Scrub's Avatar
Thanks Pont.
The 1 1/2 is a really good Idea. mine wasn't surfaced so I got out a grinder and made it smooth. I then drilled the prescribed 1 5/8 inch hole and blew right through into the case. darn.
No big deal, the bolts that hold my corp14 cover on go into the case too. I will just put a little silicon on them. I quit after the pilot hole as I am going to change out all the inards and I will finish it when I have an empty case. Fact of the matter is I am going to blow both holes through so I can get a full depth thread tap without having to buy a 20 dollar 5/8 bottoming tap. Having to buy a new 17/64 drill bit is bad enough.
I think maybe the ones that are drilled might have a little deeper casting in that area, so let this be a lesson to all of us.
Thanks to all
Scrub
Thread Tools
Display Modes
