Old 07-16-2019, 11:08 AM   #1
68Blu
Help! Plastic thrust washer and rubber ring
Hey guys, I’m in a pickle. Does anyone have the dimensions of the rubber ring (#39) in the upper steering column on a non-tilt wheel? Trying to have one made (long story) but mine is so distorted that we can’t get any good measurements. Thanks
68Blu is offline   Reply With Quote
Old 07-16-2019, 12:06 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help! Plastic thrust washer and rubber ring
Not sure if I have one out of a column or not but I will check in a few minutes. There are some good pictures of the parts in this thread (post #14) If someone else has one apart.
http://67-72chevytrucks.com/vboard/s....php?p=4800898
LockDoc
Leon
Old 07-16-2019, 01:27 PM   #3
LockDoc
LockDoc's Avatar
I don't find one in my spare parts bins. Maybe someone else will chime in on this.
LockDoc
Leon
Old 07-16-2019, 02:00 PM   #4
68Blu
LockDoc, thanks for trying!
Old 03-02-2020, 10:43 AM   #5
donrolla
I am in the same boat. My rubber ring is toast and the thrust washer is about the same. I cannot find these parts for sale anywhere. Is there a vendor that I can get these from that anyone is aware of?
donrolla is offline   Reply With Quote
Old 03-02-2020, 12:38 PM   #6
toolboxchev
Yikes, keeping on eye on this one.
toolboxchev is offline   Reply With Quote
Old 03-03-2020, 12:46 AM   #7
68Blu
I ended up having my Dad make the rubber ring I needed. I do remember seeing a guy on eBay with a NOS plastic thrust washer though. Good luck.
Old 03-03-2020, 11:35 AM   #8
donrolla
I got both parts on ebay...now I get to see if I can get it all back together properly. The parts I ordered are #3902563 and 3879747. I have a 1971 C20 with non-tilt steering so I will let you know how they work.
Old 05-07-2020, 10:42 PM   #9
Suede53
Any updates on this one? Did the ebay part numbers work? Was anyone able to get the dimensions?
I'm in the process of rebuilding my column and the rubber ring was nowhere to be found.
Suede53 is offline   Reply With Quote
Old 05-07-2020, 10:57 PM   #10
LockDoc
LockDoc's Avatar
Inside diameter is 1 3/8" with a 1/8" thickness. 13/32" tall. There is a shaved area on the outside that is 3/4" long and 1/16" thinner. I will post a picture in a while.
LockDoc
Leon
Old 05-07-2020, 11:35 PM   #11
LockDoc
LockDoc's Avatar
Here is a picture. The area between the arrows is 1/16" thinner. If a person could find a piece of an old semi or dump truck mud flap it might work to make one out of. Some of them are pretty thick.
LockDoc
Leon
Old 05-08-2020, 07:38 AM   #12
bigmac73
bigmac73's Avatar
i would check your local industrial gasket or rubber / hydraulic hose supplier and see if they have something that would work
or Grainger.com
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-08-2020, 08:11 AM   #13
Suede53
Awesome! It does look like an old mud flap. Thanks for the info. I was trying to guess the sizes from the images but this is very helpful.
Old 05-08-2020, 09:50 AM   #14
Richard2112
Richard2112's Avatar
I made my mud flaps from a rubber material purchased from Tractor Supply. They had rolls of various thickness and the flaps have lasted for years. That might be a source for material if you need to make that ring.
Richard2112 is offline   Reply With Quote
Old 05-08-2020, 11:00 AM   #15
LockDoc
LockDoc's Avatar
A guy might be able to use a piece of radiator hose too.
LockDoc
Leon
Old 05-08-2020, 12:31 PM   #16
Suede53
All good suggestions and much appreciated. I'll rummage through the "spare parts" and see if I can find something.
Old 05-08-2020, 01:18 PM   #17
67/Heaven
67/Heaven's Avatar
I have these at work we use them as sight glass seals, dimensions are close except for the height (approx 1/4" may be able to glue and stack two of them) 1/8" thick and about 1" ID (stretchable). If you are interested pm me, I am willing to send you two or three if you feel they would work for you, no charge.
Look at this link the height is not included in dimension but a quick call may be able to resolve that
https://www.superiorwasher.com/washe...D_value_+1.375
Last edited by 67/Heaven; 05-08-2020 at 01:51 PM. Reason: update dimensions added a link
67/Heaven is offline   Reply With Quote
Old 05-08-2020, 05:18 PM   #18
67/Heaven
67/Heaven's Avatar
Suede53 received your PM I will be sending you four this evening. You may want to use the handles of some channel lock pliers and leave one or two to stretch overnight. Hope this helps.
Old 05-08-2020, 05:29 PM   #19
LockDoc
LockDoc's Avatar
They have to fit over the center part of the white plastic thrust washer so he can use that as a guide. He can warm them up with a heat gun or hair dryer also.
LockDoc
Leon
Old 05-08-2020, 05:52 PM   #20
67/Heaven
67/Heaven's Avatar
LocDoc thx for the dimensions as far as the center goes if needed find someone with a lathe and have one turned from teflon
Old 05-19-2020, 07:55 PM   #21
Suede53
Thanks again for everyone's help. I have been busy with some other things so I haven't been able to do much with the washer 67/Heaven sent.
I did contact Superior Washer. They don't have any stock and the minimum order is for 100. The dimensions they gave are 1.687 OD x 1.375 ID x .125 Thick (PN 850-47-125).
Thread Tools
Display Modes
