![]() Join Date: Jul 2016
Tilt Colum, auto, column shift, restored...just about the real deal truck tilt
This is a motorhome conversion to which i installed a van shift tube making it exactly the same as a real truck tilt as far as lower shifter arm and center shaft length.
Its a bolt in with no modifications needed. Completely disassembled, bead blasted primed and painted gloss black. Turn signal switch was disassembled, cleaned and lubed. Bearings, pivots, etc were cleaned, lubed and then assembled and set to factory specs New tilt and turn signal levers. Includes a new neutral safety/back up switch which i just ordered and is due here Monday Here is a link to where i describe the attributes of a real truck tilt column. http://67-72chevytrucks.com/vboard/s...d.php?t=790793 $475 shipped |
Re: Tilt Colum, auto, column shift, restored...just about the real deal truck tilt
Later today i am listing another van conversion tilt, that one has the longer van center shaft and motorhome dogleg shifter arm.
Ttt
Almost Satisfied
![]() Join Date: Mar 2002
At some point you are going to post one of these when I have the money
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Ttt
Ttt
Randy, I will take this, can you swap the indicator for a over drive ? I called you and left a voice message.
#8 | |
I can swap it to overdrive, i would have to order it, i also think it may require a little fitting to install, last one i sold he had some troubles with it, i feel its nit relieved enough where the bulb is at. |
Sold pending payment to my kids toy.
Payment sent
Thread Tools | |
Display Modes | |
