Old 09-11-2019, 01:54 AM   #1
jocww
pexi glass bed
My truck is almost done, and right now i have no bed. I was going to do a wood bed, but my dad had a great idea of doing a pexi glass bed so we could show off the air bags, compressor, frame, etc. I have never heard much less have i ever seen a bed made out of pexi glass. Has anybody ever done a bed like this? I was going to a tilt bed, but if i do it this way, maybe a sliding bed, i am not sure. It cant slide all the way out, as i have tubs now... but i will need a way to access the gas filler.
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 09-11-2019, 02:00 AM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: pexi glass bed
Right off this forum:
http://67-72chevytrucks.com/vboard/s...ad.php?t=48346
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 09-11-2019, 02:05 AM   #3
MiraclePieCo
Re: pexi glass bed
I also saw this '30 Ford PU with a ribless plexi bed years ago:
Old 09-11-2019, 02:13 AM   #4
jocww
Re: pexi glass bed
awesome thank you!!
My travel blog
Old 09-11-2019, 03:21 AM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Re: pexi glass bed
Its gonna be a nightmare to clean though ..unless your building a trailerd truck...itll scratch and stain easily taking away from the look...and if you do it dont use plexiglass..use lexan or similar....
Plexiglass breaks easily..
another disadvantage is if you dont have a perfectly smooth mounting surface ,itll show every little flaw, wave and twist when the light hits it....overtighten one bolt and the distortion is awful....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-11-2019, 01:30 PM   #6
jocww
Re: pexi glass bed
The truck will not be trailered, its built to drive to shows, and hopefully do route 66 one day. I assumed it would get rocks kicked up and whatever else is kicked up in the chassis. We were planning on going to tap plastics, not sure what they have. it will be a smooth surface as i was planning on building a frame out of 1x1 square stock since i have the c notch. but good advice on torquing everything the same. I will have weatherstripping around the edges so it wont rub against the side of the bed.
My travel blog
Old 09-11-2019, 01:31 PM   #7
_Ogre
_Ogre's Avatar
Re: pexi glass bed
as long as you never drive your truck it would probably work
one trip and lexan or plexi would probably be scratched and dinged with rocks
shop air compressor timer
Old 09-11-2019, 02:32 PM   #8
joedoh
joedoh's Avatar
Re: pexi glass bed
i used to do a bunch of custom car audio setups. lexan is a better material because its super tough. when I would cut the speaker holes in 1/2" material and the customer was hanging aorund I would offer the whole install free if they could break it with a sledge hammer. one guy almost knocked himself out, he put the lexan at angle on a curb and hit it, the sledge bounced and went right past his eye. that was the end of that
lexan is much stronger than plexiglass for the same thickness, so I usually downsized the thickness. but plexi is super strong too, as long as you get it thick enough. plexi does not take distortion, if there is a screw hole there it will crack before deforming. lexan can bend almost 10 degrees cold, if you are strong enough. plexi needs special saws and bits, lexan can cut with a jigsaw and wood blade.
lexan or plexi though, I hope you have the dollars for it. my brother got a GMT400 suburban in the late 90s and wanted all his stereo installed, I did a false floor in the rear of the truck with a plexi cover over the amp racks so you could still pile groceries on it, the 40x30 piece cut to size with a finger hole was almost 300 dollars. my brother complained a lot about that price, nevermind that I had taken two days and done a competition level install for free, he had to pick up the plexi, never heard the end of it. and that was the last car I ever installed anything for him.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-11-2019, 03:08 PM   #9
mgchevyparts
mgchevyparts's Avatar
Re: pexi glass bed
20-30 years ago lots of guys use to do the floor out of plexi, especially guys doing 56 Ford F-100. I never really cared much for it. Now adays guys do it more for stereo systems
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 09-11-2019, 10:25 PM   #10
MARTINSR
MARTINSR's Avatar
Re: pexi glass bed
If nothing else covered with dust on the underside that you can't wipe clean.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-12-2019, 12:20 AM   #11
jocww
Re: pexi glass bed
Wow that's alot too think about. Thanks for all your input. Il have to see if tap has lexan
My travel blog
Old 09-12-2019, 07:14 AM   #12
youngrodder
youngrodder's Avatar
Re: pexi glass bed
All I think of when I see plexiglass beds is if you drive/wash it how would you ever get the water spots off of it....I agree it sounds like a maintenance nightmare. If you want to show off you bed just go with an actuator that raised the bed floor to expose your chassis.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-12-2019, 10:29 PM   #13
jocww
Re: pexi glass bed
I wonder how hard it would be to have that actuator run off my air bag compressor
My travel blog
Old 09-12-2019, 10:39 PM   #14
mongocanfly
Post Whore
Re: pexi glass bed
Use electric actuator.....a buddy of mine did a custom back half frame on a old Ford truck...to show it off, he just didnt put a floor in the bed
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-13-2019, 01:48 AM   #15
jocww
Re: pexi glass bed
You wouldn't have any pictures of that would you? That's what I wanted to do to show off everything. That or a tilt bed. Just not sure how to engineer it all
My travel blog
Old 11-02-2019, 11:53 PM   #16
jocww
Re: pexi glass bed
Well we took what you guys said to heart but my dad still wants pexiglass/lexan bed as we already had some sheets. So today I tacked the frame up. Still need to figure out spacers I need 3inches to clear the air tank fittings and gas cap
My travel blog
Old 11-04-2019, 01:39 PM   #17
jocww
Re: pexi glass bed
How should i mount the frame? Im torn to either weld spacers/square stock on to my c notch or should i weld some square stock to the side of the bed? If i do the c notch i can just grind it off if we dont like it. It should be strong enough as i plan on using 1x2 .08 in stock as the columns/spacers. the only problem i see is that there is no support at the front or rear of frame, and while i will only ever put light loads ie chairs, cooler, duffle bag of clothes in the bed.
My travel blog
Old 11-05-2019, 04:30 AM   #18
jocww
Re: pexi glass bed
Figured it out I made stilts front and rear.
My travel blog
Thread Tools
Display Modes
