09-17-2019, 04:06 PM | #1 |
Active Member
72 C20 Front Lowering Springs
Question..C20 front coils are NOT the same as C10 correct??
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
09-17-2019, 04:41 PM | #2 |
Re: 72 C20 Front Lowering Springs
It depends on how the truck was optioned. A C10 w/a factory big-block prob has the same coils as a 3/4 ton. They will interchange.
09-18-2019, 01:15 PM | #3 |
From what I've seen, there are 3 types of springs. If you search around for putting half ton springs on a 3/4 ton truck, you will find some threads with spring rates and such.
Spring types: 1/2 ton regular 1/2 ton heavy duty 3/4 ton regular 3/4 ton heavy duty 1/2 ton heavy duty and 3/4 ton regular are the same spring rate and installed height.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
09-18-2019, 01:16 PM | #4 |
Thread Tools | |
Display Modes | |
