09-23-2019, 08:31 AM | #1 |
Ride height issue
1968 swb c-10. 350 engine. I have installed 2" drop spindles and 2" drop springs on front. Tires are 235/70/15 BF Goodrich radial t/a. Rear has 6" drop springs, adjustable panhard bar etc. 275/60/15 tires. Same brand as fronts. My issue/ ? Is why is truck not level ? Tire size maybe ? Front measures 26 1/2" from ground to center of wheelwell and rear is 28 1/2". What gives ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
09-23-2019, 10:25 AM | #2 |
Re: Ride height issue
Are you able to throw up some pictures?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
09-23-2019, 11:35 PM | #3 |
Its not that noticable. I can live with it. Just wondering what happened. Tried to upload pics
It said error- security token missing. ??????
09-23-2019, 11:44 PM | #4 |
Make your pics smaller.
09-23-2019, 11:45 PM | #5 |
Working on pics
09-23-2019, 11:50 PM | #6 |
Pics
09-23-2019, 11:51 PM | #7 |
How ?
09-23-2019, 11:58 PM | #8 |
Bear with me. Learning how to send pics correctly
09-24-2019, 07:33 AM | #9 |
67-72 parts collector,…
Looks fine to me.
You do realize the front wheel well opening is higher (from the ground) than the rear wheel opening? I always look at the gap from the tire to the wheel arch.
09-24-2019, 12:47 PM | #10 | ||
"I ain't nobody, dork."
Also your cab is sitting lower than your bed. Are your cab mounts shot?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Thread Tools | |
Display Modes | |
