Old 10-15-2019, 09:31 PM   #1
coacharmstrong1990
Project: Sellers Remorse
So about 10 years ago I sold my dream car (truck) my 1972 GMC Jimmy. Fast forward to August and I found another Jimmy. This one is a 1971 and needs everything. It’s has the original 307/350/205 that someone has freshened up, 3.07 gears. Solid windshield frame, cut down rust free bed floor from a squarebody, firewall and frame so I’m going to start building it from the Firewall back.
-New Parts already purchased: full one piece floor pan, body mounts, core support, fender and a rust free original 68 fender
-plans- 1968 Chevrolet Front clip, ORD axle flip, 4” lift in the front, Jeep Wrangler JK front and rear seats, custom roll bar, 6.0 LS/NV4500/NP241c, 3.55 gears, Detroit trutrac front and rear. I plan on making this my daily driver.
coacharmstrong1990 is offline   Reply With Quote
Old 10-15-2019, 09:37 PM   #2
coacharmstrong1990
Re: Project: Sellers Remorse
Here’s some pics from the beginning rear down
Old 10-16-2019, 07:56 AM   #3
coacharmstrong1990
can a moderator move this to the projects section please
Old 11-08-2019, 11:08 AM   #4
coacharmstrong1990
Update
I have removed the engine and transmission/tcase, all the wiring harnesses and basically anything that is unboltable within the cab and engine bay.
after some urging by one of my friends I removed the outer cowl by cutting out the spot welds. Im sure that I have created a ton more work for myself but I will sleep better at night knowing that I treated and repaired any rust under that cowl panel.
the plan from here is to
1. cut the fire wall and A pillar away from the body and have it dipped or blasted. not sure which yet (any advice appreciated)
2. break the frame completely down and wire wheel then coat with Eastwoods Rust Preventative paint then top coat
3. Fix rust on the firewall/A pillar
4. Start building the Blazer from the ground up (i.e. 1 piece cab floor bolt on first, then the step up, then the bed floor, then bed sides and finally the fire wall.)
Old 11-08-2019, 03:00 PM   #5
jaros44sr
jaros44sr's Avatar
That is a known area for rust, but what about the w/s pillars, mine are rusty and drop chunks of rust in my lap, some day I'll address those areas, but not today. Yours look pretty solid
good luck with your build, I'll watch
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-14-2019, 02:13 PM   #6
coacharmstrong1990
The windshield pillars are prob the better parts of my blazer pre-sand blasting, which might tell a different story. the only damage i can see is where the top bolts into he windshield frame.
Thread Tools
Display Modes
