Old 12-10-2019, 07:47 PM   #1
Tuff Gong
Tuff Gong's Avatar
Tach filter for HEI connection
Anybody buy and use one of these. If so please send a link. Thank you.
Stock gauges to HEI. 350 motor 1970
Tuff Gong is offline   Reply With Quote
Old 12-10-2019, 10:01 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tach filter for HEI connection
I have never used a stock tach and HEI distributor and needed a filter. Do you have an original tach or a repro one. Have you had it all installed to see if it actually works or not? I haven't been following all of your posts so not sure. I have read about guys having problems and some of them have been caused by aftermarket ignition modules in the distributor or bad grounds.
LockDoc
Leon
Old 12-10-2019, 10:45 PM   #3
gchidest
Been searching on the best option also to put in a reproduction tach or a aftermarket tach that will fit in the space where original tach would go. Looks like a lot of people have had luck with reproduction tachs and hei.
http://67-72chevytrucks.com/vboard/s...d.php?t=698237
gchidest is offline   Reply With Quote
Old 12-10-2019, 11:31 PM   #4
Tuff Gong
Tuff Gong's Avatar
Tach is original. I just want to do it right the first time around. Maybe it’s not needed? Or if it’s an issue I will just deal with it down the road.
Old 12-11-2019, 12:28 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Tach filter for HEI connection
I have 3 trucks all of them are tack cluster and HEI with no problems.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-11-2019, 11:29 AM   #6
StingRay
StingRay's Avatar
I've never needed anything but to hook it straight up. Run em for over 20 years like that.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-11-2019, 11:54 AM   #7
Happy_dan
Happy_dan's Avatar
I have only heard that with the Petronix III ignitor module that the tach won't work.
Happy_dan is offline   Reply With Quote
Old 12-11-2019, 08:37 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Hi Brian,
Normally not needed and the tach should work just fine for you.
For what it is worth, I would be curious to see exactly what a filter does for you. All they are really for is to clean the signal line. It prevents electrical interference from other nearby wiring.
The filter will not fix a tach that does not read correctly.
Hope this helps.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-11-2019, 09:59 PM   #9
Tuff Gong
Tuff Gong's Avatar
Thanks for all the feedback. I’m installing without a filter.
Thread Tools
Display Modes
