Does anyone on here have pictures of an original 327 V8 with a 4 barrel Rochester carb, no AC, with power steering in a 67 Chevy C10? Lost the pictures we took of it when we got it home. Thanks to who responds.
Re: 327 pictures
I do, not original power steering though
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Re: 327 pictures
Here’s one I had on the phone
Re: 327 pictures
Thank you projectking
Re: 327 pictures
NP, I’ll get more. Snows blowing like a ***** tonight and I went straight into the house!
Re: 327 pictures
You want to see it without the air cleaner?
Re: 327 pictures
I can take pictures of mine if you need it but no PS or PB
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
Re: 327 pictures
Re: 327 pictures
Here you go. I have a power steering pump and ram assembly as well as another 327 at the shop if you need something else
Re: 327 pictures
The gearbox setup on the pictured truck isn’t correct but works!
Re: 327 pictures
Thank you for the pictures projectking. If I need anymore pictures I will give you a holler
Re: 327 pictures
You’re welcome, Happy New Years!
#13 |
Re: 327 pictures
Wasn't the alternator mount on the exhaust manifold in 67/68?
#14 |
Re: 327 pictures
Yes, the lower bracket bolts to the bottom hole and the alternator pivot to the top one.
#15 |
Re: 327 pictures
I will do this when I get home from work today. I'll take some with and without the air cleaner.
#16 |
Re: 327 pictures
Sorry, kind of dark, but got home late. Hope these help someone with something.
#17 |
Re: 327 pictures
#18 |
Re: 327 pictures
Thank you happy dan
#19 |
![]() Join Date: Mar 2019
#20 |
Re: 327 pictures
No sir, it is a 68. That tube helps warm the air when it cold outside. I am sure someone here has the official name. Maybe heat tube?
#21 |
Re: 327 pictures
cool man. Nice truck. I thought it was a 68. is that engine original to the truck? if so what is your Suffix code? Last 3 letters of stamped on the block behind the water pump. Thanks
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
#22 |
Re: 327 pictures
67 is a little different. Closed pcv in 67 is in the oil fill tube and the carb is a 4jet, not a Quadrajet on a 67 327. Here is a factory 67 327. It has ac and air injection that yours may not have. 67 truck 327's in all designations had a thermostat bypass as well. The 67 327 would be manual choke but I added an auto choke to mine as well as adding larger valve heads from a car.
#23 | |
Thanks for the info. How close is your bbl air breather to compressor? I have air too but I think it’s an aftermarket compressor and the stock bbl wont fit. Maybe the compressor can be adjusted? Posted via Mobile Device |
#24 | |
Re: 327 pictures
#25 |
Re: 327 pictures
It's quite a ways away. This is the oil bath breather. The paper element housing may be closer but wouldn't touch.
Thread Tools | |
Display Modes | |
